Steering draglink info required
Results 1 to 10 of 18
    Leicester
    5,696
    594
    bigyellataxi is offline
    Hi all, did anything English/European/easily available use a ball type end on the pitman arm/spindle??
    Struggling to get a Willys link, so I need something more readily available with the female ends...
    Fueled by Jim and Luckies.
    Jul 2015
    Elimbah, Queensland, Australia
    527
    1172
    HALLnRODZ is offline
    Hey Guy, been a while since I saw a stock front end on a Willys but could you A; Make a triangular steering arm to bolt onto the stub axle in the same manner as they build them for the Ford axle. You could weld the taper off any common vehicle inside the triangle part.
    B; Find a 70's G60 Patrol and check it out as they used a similar arm from steering pitman arm to front hub.
    C, Fit a centre steer rack on a cradle behind the beam axle and have luverly steering forever.
    Burn out champ 2010 Dusty's Avatar
    Northants
    1,682
    223
    Dusty is offline
    Would grinding the ball off and drilling for a tre or heim joint count as too much of a modification?
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    What diameter is the ball? 30s through late 50s Chevy trucks have adjustable ball joints on track rods and drag liinks that would be worth a look; should be plenty of them around with the number of trucks that have been clipped over here in the UK.
    But putting a tapered hole in the Pitman and/or steering arm for a modern ball joint wouldn't be too difficult, I did this one for my brother's truck.
    Stuart.
    My Intro
    Jul 2015
    527
    1172
    These are the ideas I was talking about.
    Nice work right there, stueeee!
    23,658
    Sorry, don't get your banter old chap ? Are you asking about from the steering box to steering arm on kingpin , and side steer ,using normal track rod ends ?
    Leicester
    5,696
    594
    Kev, I need a draglink to go between the pitman arm and the arm on the spindle, it has a ball on each.
    To all the others I don't want to modify the steering, just join it up :-)
    Northants
    1,682
    223
    Dusty is offline
    '49 F1 has the same style of fittings.
    The ball bolts on to the pitman arm so if you need to change it, it would still appear stock.
    Jul 2009
    three holes, wisbech, cambs
    5,167
    1003
    352 kum is offline
    consul?
    May 2016
    S E London
    948
    22
    timbo56 is offline
    Land Rover
    1. Event Organisers - Info Required
      By Roadrunna in forum On Topic
      Last Post: 09-03-2011, 13:36
    2. Steering set up info required
      By klassicdave in forum Tech Discussion
      Last Post: 14-03-2010, 12:06
    3. Mk2 Zodiac Engine Info Required
      By Zody in forum Tech Discussion
      Last Post: 18-11-2009, 22:06
    4. steering rack info wanted
      By vin likes diesel in forum Tech Discussion
      Last Post: 10-11-2009, 21:32
    5. Event Organisers - Info Required
      By Roadrunna in forum Chat
      Last Post: 14-09-2009, 00:37
