steering UJ
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: steering UJ
    Rods 'n' Sods Junkie Andy650's Avatar
    Oct 2013
    Eastleigh
    115
    16
    Andy650 is offline
    steering UJ
    can anyone identify this steering joint for me please?
    Decided to find out why the steering on my Pop was notchy & found the insides of this rather rough.
    Hopefully I can rebuild or get a new one once identified
    Thanks
    23,665
    Not neccesarily your problem. How many ujs do you have in th set up? Are they phased correctly and do you have a picture of it all set up?
    13,453
    mygasser is online now
    looks like a disassemble, grease and rebuild would help no end with that one at least.
    Oct 2013
    Eastleigh
    115
    16
    Andy650 is offline
    I have cleaned it for the pics it was full of grease & will be when I put it back together. The column has this fixed to it, then a shaft to a normal UJ which is fixed to the steering rack
    The inside surfaces of the item in the pic are pretty shot so this needs replacing.
    Mar 2010
    Gone
    918
    13
    fall-apart-dave is offline
    As said, phasing of the UJs are your problem almost certainly. Your "in" and "out" must be absolutely parallel. There are really good demo vids on YouTube about this.
    Oct 2013
    Eastleigh
    115
    16
    Andy650 is offline
    I understand about phasing UJ's but this isnt a UJ & its buggered anyway so need to know what it is so I can start looking for a new one. It also looks like this gives a small amount of lateral movement like a sliding joint so ideally I am looking for a like for like replacement.
    Milton Keynes
    1,115
    24
    Magman is offline
    It's so long since I've seen one of them I can't remember what it was on.
    It looks suspiciously like a gearing unit to assist with heavy steering without having to have pas. The column turns the gearing inside the unit which turns the outer body at a different rate. The rack clamp is fitted to the outer body independent of the top part of the column.
    Oct 2013
    Eastleigh
    115
    16
    Andy650 is offline
    Its not a reduction gear. Input to output is 1:1 Its just a bar with the 2 nylon wheels on that turn inside the housing like a CV joint. I will post some more pics when I get home later.
    Oct 2013
    Eastleigh
    115
    16
    Andy650 is offline
    This shows more detail. The splined clamp attaches to the column then the output shaft goes down to a normal UJ on the rack.
    I just need to identify it so I can go looking for a replacement.
    23,665
    Any part numbers or markings on it to give a clue ?
    1. Altered steering box
      By Jon in forum Stuff - WANTED
      Last Post: 04-06-2009, 15:53
    2. Replies: 0
      Last Post: 04-05-2009, 12:48
    3. Steering Rack size
      By 6-71 in forum Tech Discussion
      Last Post: 03-05-2009, 21:32
    4. Grant steering wheel adaptor
      By jeff66 in forum Stuff - WANTED
      Last Post: 29-04-2009, 08:09
    5. Transit MK2 steering box
      Last Post: 28-04-2009, 20:54
