suicide pop front axle?
Results 1 to 4 of 4
    Nov 2009
    north wales coast
    59
    18
    kevfromwales is offline
    right guys - few questions on the above subject
    I've seen a few cars running pop front axles converted to a suicide or similar setups- spock's build of rubellion, and shedster's modified spring to mind (I know that shedster's setup is different, with the semi (?) elliptics)
    I've had a google around, and I can visualise what I want, and where each component should be - just having trouble with the re-jigging of the actual enfo suspension bits!
    what I would like in an ideal world is the stock pop front axle, mounted with the spring either on top of the axle, or behind it, and the stock wishbone split, or some hairpins made up - and the whole lot mounted off a suicide perch from the front chassis rails
    I have a spare complete pop front end incase this goes badly tit's up, so that's not a major worry, but I was just wondering if anybody had any good ideas where to start - what to be cutting / bolting / welding??
    cheers all - kev
    Jul 2009
    Yeovil, Somerset
    1,769
    822
    Stroprock is offline
    Re: suicide pop front axle?
    Not really a suicide front end, but this is what I did. I wanted to keep the axle as stock as possible, so I didn't split the wishbones or use hairpins.
    Official RnS Addict issigone's Avatar
    4,050
    621
    issigone is offline
    Nov 2009
    north wales coast
    59
    18
    right - stoprock - what you have there is basically a stock pop setup as far as I can see - that's what I have now
    issigone - that's looking more promising, but have you mounted the spring behind the axle there? - it's a bit hard to mke out with my myopic vision and teeny tiny pc screen!
    - any more info on what you had to do to make your setup work?
    kev
  1. Hairpins for front suicide style axle and batwings
    By crozch in forum Stuff - WANTED
    Last Post: 18-05-2010, 00:53
  2. Ford Pop front axle & hubs
    By THE POP SHOP in forum Stuff - WANTED
    Last Post: 06-05-2010, 15:33
  3. early ford beam front axle
    By englishhemi1932 in forum Stuff - WANTED
    Last Post: 21-04-2010, 20:41
  4. Drop Tube Front Axle
    By v8 jago in forum Tech Discussion
    Last Post: 09-03-2010, 21:52
  5. pop front end axle
    By movinghotods in forum Stuff - WANTED
    Last Post: 22-09-2009, 22:45
