Swinging gate Bosch AFMs
Results 1 to 6 of 6
    23,364
    Do they have to be mounted upright as per OEM or will they work tuned through 90 degrees so the gate is vertical rather than horizontal ?
    North Yorkshire
    355
    25
    FlatheadFordV8 is offline
    Hi Kev,
    I assume you mean the mechanical system, like the K-jetronic etc.
    They are pretty finely balanced, and I suspect that the unit will have to be vertical, as you may find that it does not sit properly at the idle position, and that there may be more friction affecting the movement.
    You will have no doubt gone through the same thought process as me and I think that the only way to find out would be to lay a unit on it's side and see if the paddle changes position.
    Not a lot of help really, but I thought someone should have a go at answering the question.
    23,364
    I did go through that thought process and actually tried it this morning
    It's Bosch system on a Pinto EFI .
    There is a spring that appears to hold it shut so my plan is to fire it up in the correct position and then shift to the alternative and see if there is any difference as failing anyone else having tried it it'll be the only way for me to find out .
    It's just that it gains me valuable space if it will work .
    North Yorkshire
    355
    25
    I think that system will be a lot more forgiving, as I do not think that gravity plays a part in it's operation.
    The K-jetronic system, had counter weights in it, and was slow to respond, and difficult to adapt to anything other than a standard setup.
    Aug 2009
    Chatham
    336
    Avenger is offline
    It makes no difference to the operation which way they're mounted.
    Fit vertically if fits better that way, it will work fine.
    Did that on one of the installs I've done.
    Nick
    23,364
    Cheers Nick, I've since found some pictures of instals like that as well. It'll certainly make life easier
    1. Tial V60 Waste gate inlet flange
      By Crank 2 in forum Tech Discussion
      Last Post: 17-05-2010, 12:11
    2. What time will the gate open for sunday cars
      By REDMAD in forum On Topic
      Last Post: 28-08-2009, 13:44
