Tacho calibration problem!
Results 1 to 6 of 6
    Jun 2009
    Yorkshire
    22
    Stan is offline
    Wonder if anyone knows an easy solution to this?
    I've got a tacho designed for a bike that I'm trying to fit on my pinto powered pop. Trouble is it shows double revs which I assume is because it's set up for a twin cylinder. It's a sealed unit so I can't get inside easily. Anyone know if there is some kind of device I could wire into the signal wire to make it read correctly????
    Stan
    Official RnS Addict UK RUSS 1960 OLDS's Avatar
    Jul 2009
    HUNTINGDON UK
    11,239
    10317
    UK RUSS 1960 OLDS is offline
    Hi Stan,
    I havn't seen him about on the forum tonight, but "sidspop" might be your man for this problem.
    Cheers.
    Russ.
    Jun 2009
    Yorkshire
    22
    Stan is offline
    Cheers Russ I'll look out for him.
    Stan
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Hi there, looks like I have found you. Looking at it very simplistically, if your tacho is reading twice what it should, then you need a divide by two box of tricks. 2000 pulses in gives 1000 pulses out. But to be perfectly honest, I do not have a clue as to how to make one.
    I know James Murray is a bit of a whizz with electronics, and there may be others on here who could assist.
    Jun 2009
    Yorkshire
    22
    Stan is offline
    Thanks Sid. Funnily enough just got back from Maplins and have tried their "solution".
    No joy with the resistors they supplied. As I have now managed to expose the dial I think I'll have to resort to some careful manipulation of the graphics!!!
    Rods 'n' Sods Junkie Fl@pper's Avatar
    Mar 2011
    Cheltenham Glos uk
    255
    7
    Fl@pper is offline
    You only get one lap of life so why not ride it Flat OUT !!!!
    1. indicator wiring problem!
      Last Post: 21-06-2009, 18:41
    2. Tacho on HEI Dizzy ?
      Last Post: 07-06-2009, 14:09
    3. Electrics problem on my daily
      By Hemi Bucket in forum Tech Discussion
      Last Post: 17-05-2009, 20:01
    4. 52 mm old style tacho
      By kapri in forum Stuff - WANTED
      Last Post: 16-05-2009, 22:39
    5. 1st gen Camaro tacho question
      By evilzee28 in forum Tech Discussion
      Last Post: 10-05-2009, 20:26
