Tachometer wiring
Results 1 to 3 of 3
    Jul 2009
    Yeovil, Somerset
    1,761
    816
    Stroprock is offline
    Tachometer wiring
    I am trying to wire my tachometer to my rover v8. I have done it all as per the diagram except the positive to the ignition switch. My car has two switches, one small toggle switch for the coil and large button for the starter. I have a + battery terminal post on the firewall which has a safety cut-off switch between it and the battery. Does the positivetach wire go to the toggle switch so it is only live when the ignition is on, or to the battery terminal post? I only turn on the safety cut off switch when I starter anyway, so it would not drain the battery overnight or anything.
    YamYam central
    3,489
    453
    74
    sidspop is offline
    To the toggle switch, so the tacho is live when the coil is.
    Jul 2009
    Yeovil, Somerset
    1,761
    816
    Ok, thanks sidspop
    1. 80s Firebird alternator wiring
      By zephyr in forum Tech Discussion
      Last Post: 01-10-2009, 17:32
    2. Wiring an Autometer Rev counter ?
      By Tarmac Tanner in forum Tech Discussion
      Last Post: 28-09-2009, 16:39
    3. Wiring loom
      By highlandrodder in forum Tech Discussion
      Last Post: 27-07-2009, 22:34
    4. wiring w/motor
      Last Post: 09-07-2009, 14:11
    5. indicator wiring problem!
      Last Post: 21-06-2009, 18:41
