Testing water pump without stripping down - checking suggested method
Results 1 to 9 of 9
    Rods 'n' Sods Junkie TheWebDesignCompany's Avatar
    Jun 2016
    Southend on Sea
    227
    TheWebDesignCompany is offline
    Hi, I'm still working on identifying the underlying cause of my overheating at idle issues.
    A mechanic today suggested that it could be a broken water pump and the engine cools thermally while driving along, but can't cope at idle.
    (Sounded reasonable to me) So to test the water pump without stripping down the engine, he said to disconnect the top radiator hose (& presumably the thermostat) and start the engine with the hose disconnected and pointed away from the car. If the water pump is working correctly then it should fire water out of the hose when the engine fires up?
    Has anyone done this before? Should I expect to see a lot of water pumped out, or just a little bit?
    I tried to find a youtube video of this being done to compare it with, but I couldn't find one...
    Glasgow,Scotland
    2,123
    german8rcoupe is offline
    What engine?
    23,473
    Good mechanic Simpler way is take the rad cap off ,run it up to temperature until teh stat opens and then peer down the neck and watch the turbulence in the tank caused by the pump functioning . uy a contactless laser thermometer and trace water flow as well .
    Have you had the rad flow checked already ?
    Jul 2010
    Hampshire
    413
    52
    truckdoctor is offline
    I'd go along with that method
    Jun 2016
    Southend on Sea
    227
    5.7ltr sbc 350 V8
    Jun 2016
    Southend on Sea
    227
    Quote Originally Posted by german8rcoupe View Post
    What engine?
    5.7ltr SBC 350 V8
    Jun 2016
    Southend on Sea
    227
    Ive had the rad recored with a quad core so should be brand new and perfect.
    Also just had the thermostat replaced with a new 160 thermostat
    Jun 2016
    Southend on Sea
    227
    I think the method was designed to show instantly if the water pump is working or not without allowing the engine to over heat again...?
    I'm a newbie !
    Sep 2012
    Burlington, Wisconsin, USA
    2
    jmbo is offline
    Two things to consider. Water pumps seldom quit working altogether. They may leak or the bearings go bad but if the pulley moves the pump works. Common problem? check to see if the thermostat is put in correctly and not backwards. Also are you using a mechanical fan or an electric fan? Do you have a fan shroud? I assume the yellow "A" coupe is the car in question. If you are using a mechanical fan, the position of a SBC usually sits lower in the farm than the stock "A" engine. This alines the Chevy fan with the lower half of the stock "A" radiator. If you are not running it with a fan shroud, the fan will have little effect cooling the engine. Good Luck.
    1. Replies: 8
      Last Post: 11-05-2011, 07:02
    2. sbf water pump
      By moles in forum Tech Discussion
      Last Post: 20-09-2009, 18:45
    3. bbc water pump
      By 58 delray in forum Stuff - WANTED
      Last Post: 24-06-2009, 11:58
    4. Rover p6 v8 water pump (new)
      By Street in forum Stuff - FOR SALE
      Last Post: 05-06-2009, 13:28
    5. Water pump
      By sidspop in forum Stuff - WANTED
      Last Post: 02-05-2009, 16:29
