th350 - edebrock vacuum ports. what goes where?
Results 1 to 8 of 8
    Rods 'n' Sods Junkie Pittaway's Avatar
    Mar 2013
    Solihull
    469
    2
    Pittaway is offline
    may be a stupid question (if they exist)
    fitting up my hotrod for the first time, im unsure of what ports go where. i have a vacuum port on my th350,my dizzy and 2 on the front of my 1405 edelbrock. one large on small.
    could anyone point me in the right configuration of these? i believe the larger one on the carb is a PCV port? do i need this?
    thats for all info as usual
    regards
    Mar 2013
    Solihull
    469
    2
    Pittaway is offline
    just about see them on thhere sorry for poor photo
    May 2016
    S E London
    840
    22
    timbo56 is offline
    You should have two small ports and a big one at the front, big one in centre is for a PCV valve, not needed but recommended by some people, make sure it's blanked off if you're not using it. The small ones are for the distributor advance, the higher one is ported vacuum for emission controlled engines and the lower one is manifold vacuum for non emission engines, the small manifold (lower) one is also for your transmission vacuum. Make sure the big hole on the rear is blanked off, this is an additional one for servo brakes. this link may help a bit https://www.youtube.com/watch?v=vC3JbNCaOG4
    Stroker Kustom Jim's Avatar
    Bath
    4,733
    2611
    Kustom Jim is offline
    If it's an open hot rod you may not want the ugliness of the pcv tube so as said block the large central port. I use it and create a closed loop hooked in to air filter, seems to even out the crankcase huffing and puffing pressure.
    I have hooked my curve adjustable distributor and th350 to the lower port with t piece to see the full vacuum force underneath the carb butterflies.
    I understand Chevies can like a good advance and the gearbox must surely be more responsive with full vacuum.
    A static vacuum test on my hi compression cammy mill still had 17 on bottom port with vac guage but feck all on upper port so a no brainer for me.
    The sample pic hoses show them all
    Carroll Shelby
    Jun 2016
    Roswell, New Mexico
    604
    NMNeil is offline
    Mar 2013
    Solihull
    469
    2
    Pittaway is offline
    thanks guys, so the lower (right) port. tee that to transmission and distributor?
    Rods 'n' Sods Junkie C10apache's Avatar
    Jun 2018
    Aberdeenshire
    145
    6
    C10apache is offline
    Quote Originally Posted by Pittaway View Post
    I've got mine set up like the sample pic above, I get really good vacuum so never really had any issues
    Sent from my LYA-L09 using Tapatalk
    May 2016
    S E London
    840
    22
    timbo56 is offline
    Yes, like Kustom Jim says, they seem to like a lot of advance.
    1. sbc heater/water ports
      By nobody in forum Tech Discussion
      Last Post: 21-01-2012, 16:16
    2. Big Block Chevy Inlet gaskets. Hi Perf Rectangle ports
      By Eastern raider in forum Stuff - WANTED
      Last Post: 30-07-2010, 20:49
    3. In goes out?.....out goes in?
      By chevy2 in forum On Topic
      Last Post: 07-12-2009, 07:37
    4. Sand Polishing Ports
      By 53catalina in forum Chat
      Last Post: 28-05-2009, 19:26
    5. Planning required for car ports?
      By zephyr in forum Chat
      Last Post: 14-05-2009, 22:24
