Thermo switch
Results 1 to 1 of 1
Thread: Thermo switch
    S.E London
    5,717
    513
    vince-305 is offline
    Thermo switch
    When i was running the rover engine in the consul i changed the standard thermostat housing for the air conditioning one as it had a threaded hole for the air con sender which just happened to be the same thread and dia as a ford electric fan switch
    I ve just been looking on the bay and came across a stat housing for the SBC
    Does anyone know if the
    1/ The hole would be the same size/thread as the ford switch
    2/ Does the later rubber ring stat housings fit the earlier inlets
    Bit'z 'N' Piece's
    1. Making a momentary switch into latching ?
      Last Post: 24-05-2010, 19:26
    2. Adjustable pressure switch
      By kapri in forum On Topic
      Last Post: 18-03-2010, 19:04
    3. mk5 cortina switch gear
      By rootesix66 in forum Stuff - WANTED
      Last Post: 11-02-2010, 20:10
    4. single wire cooling fan switch
      By dek in forum Tech Discussion
      Last Post: 28-12-2009, 09:54
