TIG filler rods, hard facing?
Results 1 to 2 of 2
    Dec 2018
    66
    cresta pa is offline
    I need to build up a surface, it needs to be a hard surface, what filler rods would be suitable? I really dont want to spend £100 on a pack, thanks
    Welding Guru
    Apr 2012
    Runcorn Cheshire uk
    623
    524
    30
    weldtech is offline
    Is it a bearing face or shaft you are welding or a wear plate?
    If its super hard you need you could use stellite but it cannot easily be machined (normally ground) some welding supply companies split old packs of tig filler wire. Or a high carbon manganese wire such as Ardrox. You could also use super duplex if its machined afterwards.
    Not really cheap whatever wire you use. I use GWS in widnes cheshire and they normally help out with small amounts of filler wire.
