Tig welding advise
Results 1 to 7 of 7
    Walsall
    681
    6
    Adey is offline
    Tig welding advise
    i have just set up my tig a hobart 250a tigawave.
    i have never tig welded before, how do you know wjhat size electrodes tungstons and ceramic covers to use? there must be a easy way, i assume the larger the current the larger the shroud???
    i have sucessfully stuck the tungston to the metal several times, how much should stick out of the shroud please.
    what settings for the argon should i use at present i have tried 120amp and 30psi
    all your help would be aappreciated
    cheers adrian
    Rods 'n' Sods Junkie Bomber's Avatar
    Scunthorpe
    134
    151
    Bomber is offline
    http://www.millerwelds.com/resources...calculator.php try this, lots of useful info and vids
    Official RnS Addict farncombe pop's Avatar
    Farncombe Surrey
    4,274
    42
    farncombe pop is offline
    I'm only training so no expert but first of..........turn it down! the first pratice i done was welding spanner heads back on [ don't ask LOL ] and the amps were 35 for small ones and 50 for large, i have gone up to 120 but that was for large box section,
    Tig is best if you pratice on small parts / low settings then you can feel just how controllable it really is, have a look at my build thread and my hinges, good luck....paul.
    Here to help !
    Glasgow,Scotland
    2,123
    german8rcoupe is offline
    When learning, welding the tungsten to the job and dipping the rod into the tungsten are both commonplace. You will get over that eventually. ;-)
    I would turn the gas presuure down too as that will run out real quick at that psi. A gentle hiss is all that is required. Try running beads without using filler rod by "walking the cup", which is kind of hard to explain but look it up.
    Rod'a'holic rodbuilder's Avatar
    Glastonbury
    1,000
    698
    rodbuilder is offline
    Make sure you fit a ball gauge flow meter it will pay for itself in wasted gas in no time.
    I paid for a one day hands in course with a local welding training company, they set up my equipment and showed me the basics for about £120.
    http://www.codeaweld.com/
    Have a look in the yellow pages for a training company or ask about in a local fabrication company with a shortage of work someone may give you a bit of cash in hand training.
    Rich
    Herts
    4,593
    198
    WB54 is offline
    from my limited knowledge (I'm just learning too), have the gas set just enough to give you decent shielding and remember the post gas flow and to shield the weld with the torch after.
    Bigger cup for more amps and when further away from the workpiece, ie awkward gaps, extend the tungsten 6-7mm out whilst learning, helps with visibility and controling the arc. Keep the tungsten sharpened on a dedicated wheel sharpening away from the tip, I've been using a rough rule of 10 amps per 1mm of the material, probably too low but I'm not quick enough yet with the dipping of the rod and the lower AMPS is helping me not make crators and blow holes on thin stuff. I'm concentrating on weld penetration at the minute rather than nice shiny penny welds but struggling with technique.
    up north
    1,987
    35kid is offline
    try and find a local college who do evening courses and go along.
    1. o/t building advise please
      By Hot Rod Widow in forum Chat
      Last Post: 27-10-2012, 09:15
    2. log book advise
      By 100ev8 in forum Chat
      Last Post: 03-02-2010, 11:06
    3. welding s/s with mig. help/tips/advise
      By 100ev8 in forum Tech Discussion
      Last Post: 27-01-2010, 00:38
    4. Fuel pump advise please
      By 56 AUSTIN in forum On Topic
      Last Post: 07-06-2009, 20:49
    5. advise on paint colour
      By vw2v8 in forum On Topic
      Last Post: 26-05-2009, 22:51
