Trans fan switch
Results 1 to 4 of 4
    Official RnS Addict 29stude's Avatar
    Nov 2009
    chesterfield/derbyshire/uk
    738
    567
    29stude is online now
    Trans fan switch
    I have a fan assisted trans cooler. The fan is wired constantly on, but I'd like to control it via a temperature switch in trans sump. Can anyone recommend a suitable switch/sender. I've seen a few advertised, but they seem to be variable type meant for gauges.
    Also what temperature should transmission run at ideally? ( th400).
    Thanks
    Herts. and ahead of Larry :)
    2,608
    34
    chevy2 is offline
    When i ran a th350 with a decent trans sized cooler it ran mostly at approx 150 degrees F,
    At about 190 F plus its not that good for the life of the box,
    Ideally the fan would need to cut in at about 180F ish.
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    This fan switch would be about right against chevy2's advice; i.e. on at 88C 190F; off at 79C 174F
    Fan Temp Cooling Switch 88C/79C M22 x 1.5 For Kit Car Track Rally | eBay
    You can get a solder in boss for you tin autobox sump:
    Brass Solder In Bush M22 x 1.5 Fan Switch Radiator Boss | eBay
    Ally threaded bushes are available which can be TIG'd into an ally sump.
    There is a vast array of different on/off temperatures available in these switches; the degrees C on/off temperature is usually contained in the part number.
    Stuart.
    My Intro
    Nov 2009
    738
    567
    Thanks chaps. That looks pretty straightforward.
    1. Can I use this switch as a line lock?
      By Street in forum Tech Discussion
      Last Post: 07-02-2015, 09:46
    2. Ooh, can I be first....?
      By Shedster in forum History Archive
      Last Post: 09-07-2012, 12:06
    3. Ford 4R70W auto trans problem - can you recommend?
      By Pilch in forum Tech Discussion
      Last Post: 05-04-2011, 07:29
    4. How much power can a C6 trans take?
      By talk_wrench in forum Tech Discussion
      Last Post: 16-01-2010, 00:29
    5. Can someone help me...???
      By bigyellataxi in forum Chat
      Last Post: 23-04-2009, 18:31
