Tube bending theory
Results 1 to 7 of 7
    Langport somerset
    102
    101
    jonal is offline
    Tube bending theory
    Can any one tell me the theory etc for bending tube. I want to bend a piece of 22mm tube by 11 degrees and want to know if the pipe will stretch when I do this. I know there is an equation when you bend flat sheet/bar metal so am hoping someone will be able to advise me. The reason being I want to make some ladder bars and want to thread the straight bar on a lathe before I bend it and still have it come out the length I want..
    Cheers Jon..
    Glasgow,Scotland
    2,123
    german8rcoupe is offline
    You need to start with a longer piece as any bend will eat up some length.
    Draw a template and measure it.
    Jan 2010
    Barnet herts
    24
    605 heavy is offline
    You could run the the thread cutter deep into the tube , say 2" , this will give you something to play with if the tube end is too long when you bend it , or bend the tube first , cut the pipe to length & use a manual thread cutter , if you're just putting a kick in the tube (11*) then you should'nt have any issues , if you're familiar with a pipe bender all the better.
    When tube is bent it will stretch on the back (arse) & retract on the inside (throat)
    Nov 2009
    Ol'fordshire
    2,961
    88
    JackGriffin is offline
    We used to reckon on two thirds stretch, one third shrink, so the length would be calculated on the radius 1/3 from the inside of the bend, although that is only a rough guide.
    But on that small a tube and shallow a bend there will be little variation - just do as 605 heavy said.
    Official RnS Addict old pizz yella's Avatar
    Aug 2009
    Hyde Cheshire
    1,122
    68
    old pizz yella is offline
    the easiest way is trip downto bq buy a bit of 22mm copper tube and do some test bits as every tube bender gives a different length of bend due to the formers wearing from use ,custom car a million years ago did an artical about fitting roll cages and gave all the spec for bending if i remember corectly
    Langport somerset
    102
    101
    jonal is offline
    Cheers all for that, that pretty much answers my question. Next stop is to go an have a look at the formers on the bender I will use..Cheers J
    Official RnS Addict StueyT's Avatar
    Peterborough, Cambridgeshire
    2,341
    317
    StueyT is offline
    It all depends on the material, copper will stretch a bit more than mild steel. As a rule of thumb, if you were bending a 90 deg bend in mild steel, you would take off 1/2 id from where the bend needs to be, then bend it, but I would imagine for an 11 deg bend the material wouldn't move about too much. As said before leave the tube longer then cut off to length afterwards. Hope this helps. I have the pipefitters and plumbers handbook here somewhere, not sure where it is but I can have a look and see what it says in there, when I find it.
    Cheers,
    Stu.
    1. Bending 3" tube?
      By wheelie in forum Tech Discussion
      Last Post: 20-03-2010, 15:52
    2. Radiator make up tech theory Q's
      Last Post: 02-03-2010, 13:54
    3. Suspension design theory
      By dubwarrior2 in forum Tech Discussion
      Last Post: 09-01-2010, 16:54
    4. bending curves in tube
      By Tricky in forum Tech Discussion
      Last Post: 07-01-2010, 15:36
    5. Tube n pipe bending
      By scooder in forum Tech Discussion
      Last Post: 12-10-2009, 17:40
