turbo 350
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: turbo 350
    west midlands
    2,813
    259
    stevie.t is offline
    turbo 350
    hi guys, after 5 of us spending 4 hours trying to fit a torque converter i decided to leave it before something got broke, had another go tonight iv manged to get it on but its realy hard to turn and to get it of is very difficult, the gearbox has been rebuilt with heavy duty rebuild kit as this box is for towing not racing, iv fitted a couple of torque converters and i im sure theirs something not right, any help will be greatly recived, i was all set to put the engine and box in on tuesday with the Ateam but dont want to fit it till i no every thing is ok, when you fit the converter you supposed to get a couple of clunks then its in, watched a bit of you tube the guy there turned his converter with he's finger tips
    Official RnS Addict rootesix66's Avatar
    north kent
    1,112
    191
    rootesix66 is offline
    right lets start with the basics........have you counted the splines on the shaft & the torque convertor? did you apply grease to fit it? the box aint jammed in park issit? i regularly learn loads of advanced stuff & get corrected by people who understand the "basics"...if you find out what it was let us kno
    crazed country rebel
    west midlands
    2,813
    259
    stevie.t is offline
    i have not counted the splines but all the parts were orded from realsteel at the same time on the same order, i did'nt put grease on anything but did put a pint or so of trans fluid in the converter, the cente shaft in the front of the box turns by hand but does require effort, if you turn this shaft the tail shaft turns as you go through the gears it is obviusly changing gear if you put it in park you can turn the front shaft but not the tail shaft,
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Quote Originally Posted by stevie.t View Post
    Yo, BA. I counted the splines on the torque converter and the shaft, and Murdoch got out your precision measuring stick, and checked as much as he could.
    Love, Hannibal
    wolverhampton
    1,392
    redvictor is offline
    Sounds like the pump bush is tight on the converter mate. Did you check the pump half on the neck of the converter before you bolted the halves together?
    I have a tool to use but you won't.
    PS,should have used a trans builder..
    Europe's quickest and fastest street legal car. 4.09 @ 191 - 6.27 @ 237mph so far...
    IVA legal too!
    Penn Autos/Andy Frost race transmissions.
    www.redvictor1racing.co.uk
    wolverhampton
    1,392
    Quote Originally Posted by rootesix66 View Post
    It wouldn't matter if you welded the output shaft to the case.The input shaft turns independently,else when you started the car you'd be into next door's kitchen..
    IVA legal too!
    west midlands
    2,813
    259
    stevie.t is offline
    Quote Originally Posted by redvictor View Post
    is the pump the bit round the shafts held with about 8or 9 bolts in the bell housing, when you say bush do you mean the oil seal
    wolverhampton
    1,392
    LOL,you need me to explain which bits are what??
    It's the bit the neck goes into.Behind the Converter seal is the pump bush.It supports the neck of the converter.
    IVA legal too!
    west midlands
    2,813
    259
    stevie.t is offline
    i think my discription was very good, i was going to say the ogimipar next to the round thingymagigy were going to take the pump out again to double check it, i assume that the converter should turn quite freely with little effort
    THATS MR TATFINK TO YOU TATFINK's Avatar
    peterborough
    961
    75
    TATFINK is offline
    ive always found after 4 hours of trying to fit summit that dont...ive ****ed it good n proper
    1. Volvo 940 2.0 / 2.3 Turbo
      By IainB in forum Vehicles - WANTED
      Last Post: 12-03-2010, 12:43
    2. 350 SBC Turbo VS 572
      By Countryboy in forum On Topic
      Last Post: 04-02-2010, 19:22
    3. Discovery Turbo NOW!
      By dw123 in forum On Topic
      Last Post: 11-12-2009, 09:53
    4. transit turbo di
      By movinghotods in forum Stuff - WANTED
      Last Post: 03-11-2009, 11:26
    5. Turbo BHP increase??
      Last Post: 27-10-2009, 22:18
