Twin sprung thermostat weirdness - 350 SBC
Results 1 to 4 of 4
    Stroker Kustom Jim's Avatar
    Bath
    5,242
    2765
    Kustom Jim is offline
    LightbulbTwin sprung thermostat weirdness - 350 SBC
    Howdy,
    pulled the top of the engine to bits to have a poke around (more later).
    Anyhoo, found a strange looking thermostat in there.
    Never been into it before and had bought a new one in case it failed the pan of water test.
    new one on the left
    They both opened at the same rate (180) although the bigger one made creaking noises as the mechanism expanded !?
    It was slower to open and you could see scratches on the shaft thing.
    I peered into the manifold I could see where the old one had extended so much that it
    had been hitting the bottom and had very clear marks thru the discoloured metal base.
    Dunno how much it was prevented from fully opening but may be part of a general running hot bug.
    It's obviously a high tec bit of kit but not suited to a Performer manifold!
    cheers
    KJ
    I'm a grown up member now ! Bully100E's Avatar
    Sep 2010
    Northants
    40
    29
    Bully100E is offline
    The Stat on the right is out of a much later engine not your SBC that has an internal radiator bypass system, as the Stat opens the flat disc on the bottom blanks the bypass diverting the coolant around the Rad.
    Tim
    Bath
    5,242
    2765
    Hi,
    thanks for the reply. Been out for a test drive today and stayed at 170 most of the time.
    Although it did go past 200 when it got thrashed on the dyno.
    cheers
    KJ
    Sep 2010
    Peterborough
    388
    Pistonpusher is offline
    I would strongly recomend you confirm the coolant flow on the new manifold as running with a none bypass blanking stat will cause overheating if it should be fitted, better to confirm than bugger it up. Although if you have been on dyno it should have showed BUT I would confirm just to be sure. The idea of the bypass blanking stat is to ensure even engine warm up avoiding hot spots. It works by allowing coolant flow around the engine when stat is closed. when the stat opens the plate on the bottom blanks of the bypass and as Bully100E states send the coolant to the rad. A stat is never stationary and will constantly wonder so you need to ensure you have the right stat.
    1. 350 sbc engine / turbos
      By prostang in forum Stuff - WANTED
      Last Post: 07-03-2010, 15:18
    2. 350 SBC baseline setup help needed!
      Last Post: 11-02-2010, 17:18
    3. 350 SBC Turbo VS 572
      By Countryboy in forum On Topic
      Last Post: 04-02-2010, 18:22
    4. 350 sbc Eng & Trans wanted
      By chopperguy in forum Stuff - WANTED
      Last Post: 04-12-2009, 06:20
    5. 350 sbc price drop
      By 58 delray in forum Stuff - FOR SALE
      Last Post: 23-11-2009, 11:59
