UNF to metric brake connector
Results 1 to 5 of 5
    Official RnS Addict klassicdave's Avatar
    Kent
    680
    32
    klassicdave is offline
    Hi, does anybody know where I might be able to get a brake connector with male ends which has a 3/8 UNF thread on one end and an M10 thread on the other end.
    I gotta hotrod Ford and a 2 dollar bill................
    Jul 2009
    stockport
    100
    47
    woody snr is offline
    Re: UNF to metric brake connector
    hi pal u should be able to get one at your local hydrolic pipe manufactures or makers
    Leicester
    5,696
    594
    bigyellataxi is offline
    ^^^ Like Woody said, we sell them at work (Hydraulic suppliers)....
    Fueled by Jim and Luckies.
    Mar 2010
    Gone
    918
    13
    fall-apart-dave is offline
    Got a whole bunch of stuff here like that... Except I'm on a ship in the arctic So no real help there! But as already said, hydraulic manufacturers should be able to sort you out. Of, if you are feeling a bit flash, get yourself a brass or stainless solid hex rod, drill the centre, and cut your own threads (as I've often had to do for both hydraulic and compressed air fittings). You'll need a lathe too, so probably not much help there...
    Hornchurch, Essex
    2,524
    9
    30psi is offline
    Can you get an adaptor that has a 24TPI male fitting (I think this is normal on yank brakes) and a 27TPI female fitting?
    I got a new master cylinder delivered yesterday, it's been tapped out to 24TPI. I also ordered a brass block that screws in to it, but it gets very tight quickly so I checked it and it's been cut at 27TPI.
    1. Brake tech
      Last Post: 12-05-2010, 10:32
    2. Another brake question...
      By 2doorConsul in forum Tech Discussion
      Last Post: 20-04-2010, 15:25
    3. m16 brake calipers
      By harris66 in forum Stuff - WANTED
      Last Post: 04-09-2009, 12:20
