I have upgraded the engine in my consul MK2 and decided to change the universal joints.
The fitting was easy enough but there is play albeit small
Its as though the joint diameter is slightly short
Is there a fix for this?
A poor mans body is a rich mans vehicle!
i take it you mean propshaft uj's? if so then if there's still any play like you describe it sounds like you got/were supplied with the wrong uj's.
Yes propshaft U/J,
I thought that might be the case
I was just toying if its feasible to put a shim behind the cir clips?
Unless the shims are equal each side it will vibrate badly. Best to get the right uj.
Neil.
Nice one, appreciate the help
