urgent help needed please
Results 1 to 10 of 16
    Nov 2009
    sidcup
    159
    20
    jimo62 is offline
    Exclamationurgent help needed please
    hi just seen a rover sdi 3500 1978, with a range rover 4.6 engine in it....
    with manual gearbox....car drove great...but low oil pressure at 20-29psi,,
    opened up oil filler neck which protrudes about 3 inches...had that creamy gunk all inside.....also when i pulled out dip stick same there oil and creamy gunk....said that might because cars not used a lot..?????
    we then went for a 15 minute drive..i checked the oil again....mixture of both oil and creamy gunk....any ideas ....please....
    Rods 'n' Sods Junkie cudaboy's Avatar
    Feb 2010
    vale south wales
    325
    10
    cudaboy is offline
    could be condensation where not used,my gs used to suffer with it bad, oil pressure low but oil could be contaminated or poo. it losing any water or getting hot?
    Col
    Heavy Oiler Col's Avatar
    Feb 2010
    berks
    2,502
    299
    Col is offline
    Oil pressure sounds about right for a Rover. Could have head gasket blown or cracked head or block as worst case. Was there A/ freeze in rad? Milky residue in oil filler could be condesation but oil like mayo on the dipstick shows a significant amount of water has got into oil.
    Official RnS Addict tatuu's Avatar
    Nov 2009
    west sussex
    1,144
    44
    tatuu is offline
    walk away or haggle like a loony mate, the 4.6 is a notorious engine for f'ing up.
    best to swap it out for a tvr tuned one or a 3.9.
    KICK IT IN THE GUTS & GO FOR GLORY
    Nov 2009
    sidcup
    159
    20
    jimo62 is offline
    Questionno overheating
    Quote Originally Posted by cudaboy View Post
    no car was warmed up drove about half hour....no smoke or anything>
    Nov 2009
    sidcup
    159
    20
    jimo62 is offline
    Questionoh oh no
    Quote Originally Posted by Col View Post
    there was some mayo on dipstick mixed with oil....guy has only owned car for 4 months..its a range rover 4.6 engine rebuilt by sia engineering about 5 years ago...oops...its RPI engineering in Norfolk
    Last edited by jimo62; 27-02-2010 at 22:03. Reason: wrong info about engine rebuild
    camaro89
    Aug 2009
    dartford
    121
    14
    camaro89 is offline
    rover 4.6 engines are prone to head gaskets and blocks cracking
    Nov 2009
    west sussex
    1,144
    44
    tatuu is offline
    once the oil is contaminated it wont clear mate, you need to flush it out & change the oil.
    it could well be condenation it depends on the journey lenghts it's had & wether its been booted from cold.
    my mrs had a fiesta that always creamed up the rockerbox even though i
    cleaned/checked/stripped/rebuilt it! had to put it down to short journey driving in the end.
    N.H.R.C. Blackcoupe's Avatar
    Sep 2009
    Co.Durham
    591
    13
    Blackcoupe is offline
    i bought a 4.6 a while back it was very cheap as the block had slipped a liner in(if i remember correctly) number 1 cylinder.it was already in bits.
    bought a new 4.0 block from v8 tuner(better block than the 4.6 and everything is interchangeable) pressure tested everything 100%,then swapped eveything from the 4.6 to the 4.0,well worth it in the end.the 4.0 block was about £380.
    Official RnS Addict Ratty's Avatar
    Narfuk
    778
    Ratty is offline
    If its got mayo on the dipstick after a half hour drive its a got more water in the oil than from condensation IMO , there's a leak into the oil somewhere . As others have said , head gasket at best , cracked block at worst . Haggle on the worst and ask yourself why he's really selling it so soon after purchase ...
    I joined a nudest colony the other week . The first few days were the hardest ...
    1. Urgent help needed
      By fozwanger in forum On Topic
      Last Post: 22-09-2013, 18:57
    2. Ridiculous rear spoiler and hood scoop needed urgent
      By Battersea Boys in forum Stuff - WANTED
      Last Post: 17-05-2010, 21:47
    3. \Urgent Hotrods and Hills
      By speedemon32 in forum On Topic
      Last Post: 12-05-2010, 15:02
    4. Urgent appeal for info
      By cool4door60 in forum Chat
      Last Post: 21-01-2010, 20:47
