v6 rev counter to v8 help
Results 1 to 10 of 12
    Rods 'n' Sods Junkie F-THIS's Avatar
    nelson. lancs
    297
    66
    F-THIS is offline
    hi guys wanted to use some clocks from a jag but the rev counter is from a
    v6 as i am running a v8 how can i convert it to run on v8 if this can be done. i would be most greatful for any help manys thanks
    [ WINNERS NEVER QUIT AND QUITTERS NEVER WIN.
    Hornchurch, Essex
    2,502
    9
    30psi is offline
    You can buy something like this:
    http://www.dakotadigital.com/index.c...rod/prd127.htm
    Some people have made their own, but unless you're a bit of a geek it's probably not the easiest thing to get right.
    Walsall
    681
    6
    Adey is offline
    the conversion only requires a change in the capacitor on the clock, if you google it it may come up with the valve you need to change to
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Or possibly change the face?
    Does it work on an 8, but read too much?
    Official RnS Addict UK RUSS 1960 OLDS's Avatar
    Jul 2009
    HUNTINGDON UK
    11,239
    10317
    UK RUSS 1960 OLDS is offline
    Quote Originally Posted by sidspop View Post
    Hi Sid,
    In my experience they work , but as you say read too much, in fact should be a third (33%) too much as an example a true
    1500 = 2000
    3000 = 4000
    4500 = 6000
    6000 = 8000
    Which is where you may have a problem (i am assuming we are talking XJ6/40 rev counter here) as if i remember correctly the jag rev counter only goes up to 5500 which would only allow you a true RPM of approx 4200. If it is an early smiths/jaeger dial you may find it has got a plastic potentiometer inside (normally accessed via a plastic/rubber bung on the back of the instrument/dial you can use this to adjust the reading of the rev counter.
    Sid,
    Are you anywhere near Andy Frost's place
    My mate is going up there Saturday am (i may also be going with him) but if you still need it i can send the Consul starter motor up with him, assuming Andy doesn't mind holding it until you collect. Just a thought.
    Cheers.
    Russ.
    nelson. lancs
    297
    66
    F-THIS is offline
    rev counter
    Quote Originally Posted by UK RUSS 1960 OLDS View Post
    Hi Sid,
    1500 = 2000
    3000 = 4000
    4500 = 6000
    6000 = 8000
    the clocks are from a series two xj6 i think but will check in morning in garage the rev counter does go upto 5500 thanks for you help
    Sid,
    Cheers.
    Russ.
    nelson. lancs
    297
    66
    F-THIS is offline
    rev counter
    have not tried yet truck still in progress but the clocks are in very good condition and would like to fit in my 56 f100 somthing like in the picture cheers
    nelson. lancs
    297
    66
    F-THIS is offline
    rev counter
    Quote Originally Posted by 30psi View Post
    cheers
    nelson. lancs
    297
    66
    F-THIS is offline
    rev counter
    Quote Originally Posted by Adey View Post
    adrain tried but no luck mate you said you were going to have a look for me, how about the cobra boys they use the clocks a lot with v8s hope to hear from you soon mate
    Jul 2009
    HUNTINGDON UK
    11,239
    10317
    Quote Originally Posted by F-THIS View Post
    Hi F-THIS,
    Looking at your dash, am i right in assuming you are going to be using Series 2/3 XJ6 /XJ40 dials
    Early Triumph Stag dials would do it and look nice (the late ones look sh1t).
    Cheers.
    Russ.
    1. 2" Moon rev counter
      By Gasolinescream in forum Stuff - WANTED
      Last Post: 12-02-2010, 19:34
    2. WHEELS..10 x 15s.. US.Ford...and Rev Counter....
      By BRIT DIGGER in forum Stuff - WANTED
      Last Post: 18-01-2010, 10:40
    3. Wiring an Autometer Rev counter ?
      By Tarmac Tanner in forum Tech Discussion
      Last Post: 28-09-2009, 16:39
    4. rev counter settings
      By vin likes diesel in forum Tech Discussion
      Last Post: 13-06-2009, 08:50
    5. Rev counter, Hot Rod book & magazines
      By Special When Lit in forum Stuff - FOR SALE
      Last Post: 12-06-2009, 18:33
