V8 breather pipe
Results 1 to 10 of 10
    Jun 2012
    Cambridge
    251
    Ian r hall is offline
    V8 breather pipe
    My rover motor has those chrome breather caps on each valve cover. I'm getting s fair bit of oil mist coming out of them. Should I run these into a container of some sort or should one or both be plumbed back into the intake? Can't see anywhere to plumb them in, running a 390 Holley on an offy intake
    Ian
    Herts
    4,600
    198
    WB54 is offline
    Don't plumb to the carb , it saves the environment at the expense of power. You could plumb both to a catch can on install a pan evac kit to the exhaust manifold
    12,886
    mygasser is online now
    yep he'd lose a little power but if that was a concern he'd have a small block ford or chevy i guess not a rover. a pcv valve in one valve cover grommet fed to manifold vacuum and either the existing breather or a piped one to the air filter base in the other. the pcv will let the motor suck the oily fumes in and burn them and the other side will draw in clean air to the crank case vacuum. if the motor's really breathy the 2nd piped breather to the air filter may be best. good luck, neil.
    Jun 2012
    Cambridge
    251
    Where would I plumb it (other than into the air filter) only seeing a fitting for the servo
    Ian
    12,886
    if you mean the pcv then holley carbs usually have a larger pipe sticking out either under the rear float bowl or out the side under the vacuum secondary diaphram housing. that'll do it or fit a vacuum fitting in place of one or the bungs in the inlet (they normally have at least 1 or 2 going into the intake runners/plenum).
    Jun 2012
    Cambridge
    251
    Nope, I haven't got it, does the pcv allow fumes out of the engine and back into intake or does it let air into the engine?
    Can't see where I can plumb it in, will put a pic of the motor up tomorrow
    Thanks
    Ian
    Herts
    4,600
    198
    WB54 is offline
    Quote Originally Posted by Ian r hall View Post
    Thanks
    Ian
    It goes to the large port in the baseplate of the carb.
    12,886
    12,886
    Thanks
    Ian
    re the pcv, the fumes go through the pcv to the inlet. clean air is drawn in through the other side breather.
    Jun 2012
    Cambridge
    251
    Righto, cheers for that.
    1. Tube n pipe bending
      By scooder in forum Tech Discussion
      Last Post: 12-10-2009, 18:40
    2. AN JIC 37 degree pipe flare tool?
      Last Post: 12-10-2009, 14:18
    3. Balance pipe?
      By Neil G in forum Tech Discussion
      Last Post: 01-10-2009, 17:49
    4. Replies: 10
      Last Post: 20-09-2009, 18:15
    5. Servo pipe twin screw in union V6 Essex
      By petespops in forum Stuff - WANTED
      Last Post: 02-06-2009, 22:19
