V8 Discovery as donor vehicle
Results 1 to 9 of 9
    I'm a grown up member now ! Disco Stew's Avatar
    Aug 2011
    Holmfirth
    45
    19
    Disco Stew is offline
    I've been looking around for a cheap V8 donor vehicle and rusty Discoverys look like good value. My question is, can you use the gearbox in a rear wheel drive car or would I need an alternative?
    Thanks
    Having a cuppa jez r's Avatar
    Manchester
    2,629
    488
    jez r is offline
    If you search around the "garage" section there's a thread by a chap who mounted a Ford F100 truck body onto a stock Range Rover chassis. It looked pretty good and if I remember right he kept the 4 X 4. Now i don't know how similar the Range Rover and Discovery chassis are but it should be some usefull reference material.
    (sorry can't find the actual thread right now but if I find it later I'll post the link here)
    Aug 2011
    crawley, west sussex
    152
    18
    asp383 is offline
    from memory, the 'classic' range rover, series 1 & possibly series 2 (td5) disco's are the same chassis (the td5 normally has air suspension on rear axle, but can also get coil spring conversion if it fails, which is common) ... 100" wheelbase (from memory) & not to be confused with the seies 2b forward control chassis.
    if you wanted to put the engine & transmission into another vehicle, you'd need to have the transfer box modified to just 2wd & you can have it locked in high range as a cheaper option to having new gears fitted.
    depending on the condition of the disco chassis, then i'd agree that doing a body swap (if pickup or van) would probably be the easier option.
    if it's to go in a car, then do away with the disco trans & as the 3.5 is still the faithfull old v8, you can pick up the sd1 transmissions or adaptor plates/bell housings to fit other tansmossions
    13,283
    the 5 speed manual is basically an sd1 box with a transfer case on the back so needs a tail housing/shaft change. the 4 speed auto is a zf again with a transfer case. apparently the rover bellhousing and convertor bolt up to a jag (rear drive) zf box so ok there too.
    Aug 2011
    152
    18
    asp383 is offline
    wasn't the earlier classic range rover 3sp auto the chrysler torqueflight 727?
    or am i thinking of something else?
    Aug 2011
    Holmfirth
    45
    19
    Thanks, that is really useful. I was thinking about just using the engine and box so if you can swap some bits to make it a normal 2wd 5 speed, that could be a way forward.
    1972 Formula 350 owner Marc's Avatar
    Jun 2010
    Suffolk
    673
    102
    Marc is offline
    Quote Originally Posted by Disco Stew View Post
    Is it not the LT77 box thats a standard sd1 5 speed that will bolt straight onto the rover v8? Had one in my zephyr behind a 3.5. You can go the route of using a tvr bell-housing and using a sierra borg warner T5 gearbox, but as i found out, this works out to be a more expensive option!
    Marc
    Cheltenham
    4,076
    601
    fozwanger is offline
    The RR bell housing is a lot deeper and the flywheels are a lot heavier (low revving mud plugging torque) and I believe that you can unbolt the transfer box and get a yoke thingy that will allow you to bolt up to it (plus they have a 10 1.2" clutch). R380 boxes were also used. If your gonn go down this route it'll probably be cheaper to get an SD1 or sherpa box if you wanna 5 speed. If not worried about cruising speeds get a P6 4 speed, better acceleration........
    May 2010
    lichfield staffs
    4,451
    407
    streetfighter is offline
    Quote Originally Posted by asp383 View Post
    for some reason the 3 speed in the range rover isn't a very good box, the 4 speed is much better. I am the guy who's thread is the f100 onto range rover, this was achieved using an LSE classic range rover, they are 8inch longer than a normal range rover, also comes with air suspension and this one came with the much stronger 4.2 v8 engine.
    1. Donor Vehicle (or chassis) wanted for new project
      By Traffic Violator in forum Vehicles - WANTED
      Last Post: 18-03-2011, 18:54
    2. Lexus ls400 donor car
      By JonF in forum Vehicles - FOR SALE
      Last Post: 02-05-2009, 15:30
    3. VW Camper needed for as a wedding vehicle
      By Battersea Boys in forum Chat
      Last Post: 27-04-2009, 18:38
    4. Any vehicle on unleaded
      By sidspop in forum Chat
      Last Post: 24-04-2009, 09:38
