v8 efi to carb
Results 1 to 9 of 9
Thread: v8 efi to carb
    I'm a grown up member now ! sprocky's Avatar
    Feb 2013
    redditch worcestershire
    74
    sprocky is offline
    v8 efi to carb
    Hi guys can any one give me some advice ive got a 3.5 v8 efi engine comeing from a mate it is a 1992 from a range rover going to put a pair of s use on it my gestion is is this a easy conversion and can I keep the same dizy on it it still has points in it many thanks in advance sprocky
    Sep 2014
    The north
    1,365
    1314
    nuggets is offline
    bolt off bolt on, wire, plumb, done
    Feb 2013
    74
    sprocky is offline
    Chears nugget but can I still use the dizy ? Or do I hear to source the vacuum type dizy
    Feb 2013
    Derbyshire
    145
    8
    docjohn is offline
    Fortunately the various versions of Lucas efi used in Range Rovers, Discoveries and others are quite primitive and don't talk to the ignition. So, you can change to carbs and keep the distributor. There have been several distributors used over the years and some are more reliable than others. If you modify the engine with a lumpier cam or worked heads then you'll probably find that the advance curve isn't suitable and you might be better with a Mallory, or mapped ignition. If it's pretty close to standard RR or SD1 spec, then the distributor that came with it will be OK.
    Feb 2013
    74
    sprocky is offline
    Thank you doc its a bog standard 3.5 v8 out of a 1992 range rover my mate at work has got it in his landy at the moment but taking it out for me as he's puting a 3.9 in it only had a quick look at it during brake time the other day its still running on points there's a little box on the side of the dizy its got two wires coming out of it ONES BLACK N WHITE THE ORTHER IS PLAIN WHITE do these go to the coil ?
    Feb 2013
    Derbyshire
    145
    8
    docjohn is offline
    Hi, sounds like you've got an early distributor. The white goes to a 12V feed off the ignition - the coil +ve terminal is the usual place. The white/black wire goes to the -ve terminal of the coil. Cheers, John
    Feb 2013
    74
    sprocky is offline
    Mañy many thanks John ow ya a few bears . so its back to basiciks old school wireing
    Feb 2013
    Derbyshire
    145
    8
    docjohn is offline
    You're welcome!
    May 2010
    lichfield staffs
    4,451
    407
    streetfighter is offline
    1992 should be 3.9? and range rover engines are usually low compression.
    1. efi to carb
      By sprocky in forum Tech Discussion
      Last Post: 13-05-2014, 21:54
    2. Rover EFI to Carb
      By Iggy in forum Tech Discussion
      Last Post: 18-04-2011, 20:04
    3. rover efi or carb
      By gordo in forum Tech Discussion
      Last Post: 11-09-2010, 13:39
    4. sbc carb and manifold
      By neil harris in forum Stuff - FOR SALE
      Last Post: 09-05-2009, 14:24
    5. Holley or Edelbrock Carb
      Last Post: 28-04-2009, 12:30
