v8 into mk1 consul
Results 1 to 7 of 7
    Jul 2009
    baldock herts
    167
    cosxr2i is offline
    v8 into mk1 consul
    hi guys i need as much info as i can get on this swap please
    how much needs to be cut out of bulkhead
    im going to be using a auto box so any advice on swapping from manual over and anything else i need to know lol
    thanks guys
    I'm a grown up member now ! largeeng's Avatar
    Oct 2009
    East Peckham,Kent
    83
    63
    largeeng is offline
    Hi there, on a Zephyr or Zodiac this swap is easy peasy, 302 sbf is simplicity itself but, a consul with its lesser wheelbase is a bit more tricky. As youve guessed the bulkhead will need cutting and moving back/replacing. I'd mount the engine as you would on a Zephyr using the through bolt type engine mounts and plate and tube adapters onto the X member. Careful measuring will tell you how much the bulkhead and tunnel will need adjusting. The g box X member wont line up with the g box mount like it does on the Zephyrs, but shouldn't be too hard to figure out. Out back, throw the original axle away and put in something stronger, 8 or 9 inch, a decent prop to match. As for the clutch pedal, just unbolt it from the the pedal box and take it out.
    Make sure you uprate the brakes all round as even a knackered v8 will pull these along quite tidy.
    This project is not too complex if you have some experience in fabricating and modding but if its your first attempt at a rod I'd suggest getting some help from others in your area who have. Go to your local clubs and cruises.
    Hope this has not put you off,
    Good luck Steve Large
    Jul 2009
    baldock herts
    167
    cosxr2i is offline
    cheers steve ,its my first attempt at a rod but i ve built a few cars up in the past so il have a go when i get the engine collected and sorted ,got the rear end sorted by the sounds of things, fingers crossed as for brakes ive just got some front struts off a mk2 consul so they will be off to gaz for a build and il start making a brake set up
    if there is anyone in my area who fancys joining me please shout and il get the bacon ,tea and beers in lol
    Oct 2009
    East Peckham,Kent
    83
    63
    largeeng is offline
    Saw your pics in the garage section, looks like your cracking on ridding it of tin worm. The strut swap isn't staight forward either if I recall. I had one years ago with this swap and if I remember correctly the Mk1 control arms dont fit the Mk2 struts, and the Mk2 control arms are longer than the Mk1 ones. Mine had the Mk2 arms cut and shut and gusseted to the correct length, looked a bit nasty though and not sure how that would go down for SVA/BIVA. It may be possible to adapt the Mk2 hubs and calipers to the earlier struts but I've not tried that myself. I spoke to the guy at Zodiac motor spares ( I think that who it was) at acruise earlier in the year and I think he said he was doing a disc conversion for the Mk1 but not sure what components are used on that or how much.
    Anyhow crack on, it'll be worth it in the end
    Steve Large
    Jul 2009
    baldock herts
    167
    cosxr2i is offline
    cheers steve ,i did email you after a brief chat we had at the pod ,about possibly doing a strut conversion on the front
    as for the mk2 stuff yeah the bottom arms are longer ,my plan was to get them made adjustable ,as that way i could correct the geometry,i had a chat with keith at zms only the other day but as im still considering airride as well i dont wanna have to butcher one of his conversions
    Official RnS Addict UK RUSS 1960 OLDS's Avatar
    Jul 2009
    HUNTINGDON UK
    11,239
    10317
    UK RUSS 1960 OLDS is offline
    Quote Originally Posted by cosxr2i View Post
    thanks guys
    Hi cosxr2i,
    Seeing as you are only in Baldock your best bet for help and advice is Dave Woodfield "MK2 DAVE" he is only up the road from you, based at Stotfold.
    What he doesn't know about MK2's isn't worth knowing.
    He has got a show on at Stotfold on Saturday 7th August so will be about all day, and as MK2 CZZ are his favorite subject striking up a conversation should be dead easy.
    Cheers.
    Russ.
    Jul 2009
    baldock herts
    167
    cosxr2i is offline
    ahh cool ive got the weekend off work as im up at silverston on the sunday,so il try to get along on the saturday thanks russ
    1. Mk1 Consul
      By cheiftn55 in forum Vehicles - FOR SALE
      Last Post: 13-07-2011, 12:45
    2. front struts for mk1 consul
      By cosxr2i in forum Stuff - WANTED
      Last Post: 09-06-2010, 16:24
    3. Did the Jago MK1 Consul Kustom survive???????
      By klassicdave in forum History Archive
      Last Post: 13-01-2010, 19:04
    4. Mk3 tina clip into MK2 Consul...
      By 2doorConsul in forum Tech Discussion
      Last Post: 08-11-2009, 13:17
    5. mk1 Zeph/Zodi/Consul NSF NSR OSR doors
      By bigyellataxi in forum Stuff - FOR SALE
      Last Post: 23-04-2009, 21:23
