V8 won't hot restart, just turns over slowly
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    Rods 'n' Sods Junkie jifop's Avatar
    hertfordshire
    151
    2
    jifop is offline
    Hey guys, can someone help me? ****ing car is doing my head in.
    I've got a 302 ford V8 which starts great and runs fine however it won't hot restart even when the engine feels cool it just turns over really slowly.
    I've tried pulling a spark plug to make sure it's not crankcase pressure and I've even run jump leads straight to the starter but it does the same thing, could the starter be over engaging as this has been suggested or do I just need another starter motor?
    nottafukinchancingham
    7,879
    57
    Torment is offline
    Starter too close to the headers....heat soak...?
    If it is make a heat shield or get a mini starter from summit racing...
    ****waiting for exchange rate rant****
    57 chevy wagon.
    540cui altered.
    hertfordshire
    151
    2
    jifop is offline
    Would that really be the cause? It's relatively close to the headers but not on them.
    Not sure how I'd fit a heat shield in.
    hertfordshire
    151
    2
    jifop is offline
    7,879
    57
    Torment is offline
    Yer.could be heat soak.
    You can get silvery wrap type stuff to cover the motor ...or wrap the headers with the heat shield stuff..
    How old is the starter...?
    57 chevy wagon.
    540cui altered.
    7,879
    57
    Torment is offline
    57 chevy wagon.
    540cui altered.
    I'm a newbie !
    Nov 2011
    Maidstone
    5
    CRIPPSY is offline
    I had this problem with my 351W with a mini starter, when hot it sounded like I'd got a flat battery or worse!!! My battery is in the boot and the cables were too small in cross section, only rated at 170 amps. Now changed to a cable rated at 345 amps (over 13mm diameter) and no problem at all, even after 120 miles of motorway driving. I also ran an earth from the battery to the starter motor bolt at the same time. Tried a heat shield before upgrading the cable and it was a waste of 50 quid!!! Got my cables and fittings from 12 volt Planet 01865 236 446 or order over www. Superb service, almost next day service. Hope this helps. I've got Sanderson headers and my downpipe is closer to my starter than yours so I'm not convinced you've got a heat sink problem. I'm no expert just speaking from experience and what's worked for me having spent 18 months trying different starters and batteries and spending loads of money!!!!
    I'm a newbie !
    Nov 2011
    Maidstone
    5
    CRIPPSY is offline
    Should've said in my post my engines in a 1950 Ford Anglia (Pop) so it gets very hot (understatement of the day!!) in the confined engine bay, you seem to have a significantly larger space around your engine and headers. Good luck!
    hertfordshire
    151
    2
    jifop is offline
    Hmm lots of possibilities, I'm not sure where to start. It's been over two hours now, it's sill slow as hell and not firing up.
    I could move the battery to the oppositesidr of the engine much closer to the starter and use a thicker battery cable.
    Would that be a good first start or is it likely still to need wrapping?
    hertfordshire
    151
    2
    jifop is offline
    I'm also wondering if the battery isn't man enough it's a 60AH 12V standard car jobby
    1. just had a make over after 10yrs
      By homer in forum The Showroom
      Last Post: 16-12-2010, 20:49
    2. Replies: 16
      Last Post: 04-10-2010, 05:17
    3. Just won bid on the bay........
      By Ratrod 1 in forum The Shelf
      Last Post: 20-04-2010, 21:25
    4. Replies: 1
      Last Post: 09-03-2010, 20:19
