Valve cover baffles and bolts??
Likes Likes:  1
Results 1 to 10 of 12
    Rods 'n' Sods Junkie C10apache's Avatar
    Jun 2018
    Aberdeenshire
    164
    6
    C10apache is offline
    Hi do I have to install the baffles in my valve covers?? The screws supplied are like butter, screw heads minced already,
    Also I need longer bolts anybody know the thread size for a 350sbc head??
    Regards Stuart
    Sent from my LYA-L09 using Tapatalk
    Jun 2018
    Aberdeenshire
    164
    6
    Quote Originally Posted by C10apache View Post
    Regards Stuart
    Is 1/4-20 the same as 6mm??
    May 2016
    S E London
    932
    22
    timbo56 is offline
    The cover bolts are 1/4 UNC and not the same as 6mm, the baffle bolts on mine were a self tapping type thing with spring washers, I also used loctite on them. Don't do the valve cover bolts up too tight either or they tend to leak. Why do you need longer bolts?
    Edited, the baffle bolts may even have been phillips head self tapping screws, will try and check. Oh and yes you should fit the baffles or it'll **** oil out of the breathers
  5. LikesTorment liked this post
  6. Remove Advertisements
  7. #4
    May 2016
    S E London
    932
    22
    timbo56 is offline
    https://i.ebayimg.com/images/g/RSQAA...rD/s-l1600.jpg They are a self drilling type screw, it that what you have?
  8. #5
    Jun 2018
    Aberdeenshire
    164
    6
    Quote Originally Posted by timbo56 View Post
    I'm fitting these ignition wire separators so they run down the side of the valve covers, with the larger thickness of the covers and new Gasket the bolts I have are too short
  9. #6
    Jun 2018
    Aberdeenshire
    164
    6
    I can get the screws in so far then they stop, I've got some self tapping screws I can use
  10. #7
    May 2016
    S E London
    932
    22
    timbo56 is offline
    I would just make sure they're not tapered self tapping screws, you don't want them falling out. For the bolts I find Spalding Fasteners pretty good, Great deals from spalding-nut-and-bolt in UNC- | eBay Shops
  11. #8
    Jun 2018
    Aberdeenshire
    164
    6
    Yeah they are similar to the crap ones I got but without the blade on the bottom,
    My PCV and oil fill cap are nice and tight tight in the valve cover holes so would I still get oil coming out if I don't fit the baffles??
    Regards
  12. #9
    May 2016
    S E London
    932
    22
    timbo56 is offline
    The PCV should be OK but assuming the oil fill cap has vent holes underneath then it'll fill with oil and leak over the cover. You need some sort of breather or the crankcase will pressurise and possibly blow a seal or gasket, I'd persevere and fit them, did you fit the washers and if so can you carefully drill the holes a bit deeper?
  13. #10
    Jun 2018
    Aberdeenshire
    164
    6
    OK cool no worries thanks, yeah I'm going to go down to my Dad's tomorrow and drill them a bit further
    Would a tiny amount of high temp RTV work on the screws to help secure them??
    Regards
    1. valve cover t-bolts
      By customville american in forum Stuff - FOR SALE
      Last Post: 29-03-2016, 12:04
    2. valve cover bolts
      Last Post: 29-03-2016, 12:01
    3. ARP SBC Brodix Valve Cover Bolts
      By TheChief in forum Stuff - FOR SALE
      Last Post: 08-07-2013, 10:38
    4. Sump baffles
      Last Post: 30-09-2010, 14:41
    5. exhaust baffles
      Last Post: 28-12-2009, 16:46
