Valve Spring Pocket Clearance
Results 1 to 9 of 9
    Official RnS Addict heavychevy's Avatar
    Jun 2009
    Sweet Home Northampton
    1,254
    54
    heavychevy is online now
    I am fitting different valve springs and they are slightly bigger diameter. They take up nearly all the clearance in the pockets in the head. Best described as a snug fit Will this be ok? How much clearance is needed? Heads are ally and there are the steel bottom retainer shim things there.
    Nov 2009
    Ol'fordshire
    2,933
    88
    JackGriffin is online now
    Do the spring manufacturers give any figures? What about the retainers - are they bigger to suit the springs? I guess aluminium heads will eventually wear to the correct size if they are a bit tight
    Jun 2009
    1,254
    54
    I've struggled to find a figure, I e-mailed them and they said "as long as it is at least zero they will work fine". This didn't fill me with confidence so I am looking for other opinions. The top retainers are new to suit the springs. I also figured the springs would win in a battle with the heads. The fit is that snug that I have to find which end of the springs are the best fit as one always seems to be a bit wider. I am reusing the bottom shim/ inner retainer.
    8,854
    1759
    blackpopracing is offline
    I'm no expert so only take my advice lightly, but if the springs don't actually bind/grip the ally pocket then I think you are ok.
    Official RnS Addict Slamera63's Avatar
    Feb 2010
    Hull, Yorkshire
    1,957
    Slamera63 is offline
    I would check that they are seating down properly, and also check the inner clearance of the valve stem seal to the spring because sometimes they need an alternative stem seal that may require some machining.
    It's only funny till someone gets hurt..........then it's friggin' hilarious
    Jun 2011
    Keeston, H/west
    1,379
    799
    Perfect65 is offline
    When double valve springs were/are used they actually rubbed slightly and were contra wound so the coils didn't actually jam together. The reason for them touching was to control spring surge at high revs so I am told (Quote - Phil Irving "Tuning For Speed"). Perhaps your set up will also control spring surge but anyhow it would seem slight friction not to be a big issue.
    Herts
    4,600
    198
    WB54 is offline
    clearance it. If the spring binds on the head, you'll damage followers, pushrods or gouge the cam. you could do it quick and dirty with a die grinder or properly and mill them oversize and concentric to the valve guide.
    Jun 2009
    1,254
    54
    The valve springs seem to vary in diameter, they are Crane 99876. I fitted a couple more today but had to reject one as neither end would fit. The present plan is to buy another half dozen and hope i get enough small diameter ones to make a full set that don't bind with the head.
    Jun 2011
    Keeston, H/west
    1,379
    799
    This is looking like the best move if the springs you are getting vary to that degree. Bore out the pockets to clear the maximum size spring you are likely to get and then you need worry no more and you will be ready for the next rebuild.
    1. SBC valve spring advice please...
      By flak monkey in forum Tech Discussion
      Last Post: 17-12-2011, 17:23
    2. Valve Spring Seat Cutter
      By 56 chevy in forum Stuff - WANTED
      Last Post: 22-08-2011, 11:46
    3. v8 valve spring compressor
      By madmax1977 in forum Stuff - WANTED
      Last Post: 10-09-2010, 20:03
    4. Flathead valve spring compressor
      By ChrisS in forum Stuff - WANTED
      Last Post: 15-04-2010, 17:36
    5. valve spring compressors
      By fozwanger in forum On Topic
      Last Post: 26-01-2010, 22:52
