Vauxhall v6 engine
Results 1 to 10 of 13
    Jun 2011
    bradford west yorkshire
    422
    481
    splitty66 is online now
    Vauxhall v6 engine
    Another engine choice. Still would prefer a v6 in the prefect, so looking around I spotted a Vauxhall omega v6 and box, has any one had any experience with this engine ?, and has any one got dimensions for the engine, if all fails there’s always the Zetec that will fit my c3 auto box, thanks ...
    Jul 2009
    three holes, wisbech, cambs
    5,143
    999
    352 kum is offline
    its a vauxhall engine thats bad enough
    13,151
    they have an oil cooler in the 'v' that fails and fills the sump with water, not good. other than that they are small and pretty good. i'd say fit a new cooler before installing the motor as insurance. neil.
    Jun 2011
    422
    481
    Cheers mygasser ,a bit more research to do on engine front , all the plumbing stuff is straight forward but the electronics are just voodoo magic to me, may need to decide soon as I’ve set a deadline for new year to have the body painted, why do I set these deadlines?, thanks for the info .....
    13,151
    Quote Originally Posted by splitty66 View Post
    make a carb inlet and use a ford edis 6 module for the spark. neil.
    Jun 2011
    422
    481
    After some research I’ve found out that it’s fly by wire throttle and the auto gearbox has its own Ecu, so getting more complicated the deeper I look, but all the info I’ve found say it’s more or less the same size as the Essex V6 so should fit in ,just waiting on a seller to measure up,even looked at a manual gearbox but then I’m into clutch pedal and cylinder which I’d have to alter the floor and bulk head, so maybe a nonstarter, choices choices........
    Jun 2011
    422
    481
    Just had another thought, could I fit my c3 auto box onto the omega auto bell housing?, they look alike and maybe just need red rolling to suit, any thoughts on this idea, cheers........
    Milton Keynes
    1,016
    16
    Magman is offline
    The earlier versions weren’t fly by wire so that could be an option.
    Make sure you change the cam belt and tensioners and make sure they’re good quality, these engines seem to eat them more so than normal belt engines and then it’s scrap.
    The 3.0 is a good quad cam engine and surprisingly compact but becoming quite rare.
    13,151
    if you're going to swap the trans' then they fitted this engine to fwd vauxhall's too. neil.
    Jun 2015
    Afghanistan
    329
    stevieturbo is offline
    Is the C3 a Ford BH fitment ?
    Do the Ford alloy V6's use the same BH pattern ? Mondeo etc ?
    1. Demon 850 carb , 1.6 vauxhall rwd engine box and axle
      By 1stpop in forum Stuff - FOR SALE
      Last Post: 24-08-2014, 15:12
    2. Vauxhall victor engine swop
      By Stuwik in forum Tech Discussion
      Last Post: 23-06-2013, 22:01
    3. Vauxhall Redtop engine n box
      By Mark in forum Stuff - WANTED
      Last Post: 21-10-2010, 01:13
    4. 1966 Vauxhall Cresta PC Rat with spare engine & box
      By Becksi in forum Vehicles - FOR SALE
      Last Post: 17-02-2010, 18:06
    5. engine weight question vauxhall v6??
      By stumpy in forum Tech Discussion
      Last Post: 05-06-2009, 16:46
