Vicious brakes
Results 1 to 7 of 7
Thread: Vicious brakes
    Nov 2011
    suffolk
    6,145
    1452
    russ6120 is offline
    Vicious brakes
    Got a problem with my brakes....they are too good!
    After ****ing around trying to repair/service them I gave up and bought new wheel cylinders (drums all round) and dumped the underfloor master cylinder and fitted a new one and a pedal
    The problem I have now is that they are too good. I only need to touch the pedal and they are on. Can I just back the brakes off to allow more fluid to be pumped or is something else going on?
    At some point when I can find the bits I’ll convert the front to discs
    Stroker Kustom Jim's Avatar
    Bath
    5,182
    2753
    Kustom Jim is online now
    My old drums all round Consul never had a servo!?
    13,143
    try blocking off the servo pipe russ. also what is the pedal ratio with the new setup? manual will be about 6:1 and servo will be about 4:1. if you have a manual pedal ratio with a servo fitted they'll be 'really, really' good.
    23,466
    Drum brakes don't like servos . Had a Rover servo on my drum braked 100E would stop the wheels DEAD at 60mph ...not so much the tyres.
    Backing the brakes off a tad wil give you a bit of inline reservoir of unmoved fluid but once passed a cerain point they will be come vicious again.
    Discs will fix it fully.
    EDIT Plus what Neil said !! Just blanking the servo vacuum will fix it.
    Nov 2011
    suffolk
    6,145
    1452
    russ6120 is offline
    Cheers chaps. I’ll disconnect the servo and see how that is....and maybe back the brakes off a little. I fitted discs to the panel van but that came as a home made kit. I wouldn’t know where to get the bits to make some for the Pontiac
    Jun 2016
    Roswell, New Mexico
    840
    NMNeil is online now
    If you recently fitted new rear brake shoes you may need to file the leading edge slightly to stop it grabbing
    Hornchurch, Essex
    2,515
    9
    30psi is offline
    Yeah and check the primary/secondary shoes are round the right way and you have correct shoe to drum clearance.
    '62 Ford Thunderbird
    '81 Datsun Bluebird SSS Turbo
