Any aircooled VW buffs on here? I need to know the compression height on Type 4 Bus 93 mm pistons with 22 mm pin as I am hoping to use them in a another engine , all other pistons I have found with the same bore have too low compression height.
I am looking for dished pistons with no valve reliefs and a compression height of 44 mm, the closest I have found so far are 42mm.
Thanks Dave
