VW T4 2.4 Diesel AAB Crank Pulley bolt removal
Results 1 to 10 of 10
    Rods 'n' Sods Junkie Matiz's Avatar
    Jan 2014
    Gloucester
    218
    16
    Matiz is offline
    So thanks to advice the 4 chewed up allen bolts on steering damper now removed.
    Cant now get the centre 27mm AF bolt undone.
    I know it should have been done up to around 330 ft/lbs !
    Haynes doenst say, so can anyone confirm that its is right hand threaded ? ?
    To save the expense of electric/bat impact gun has anyone tried on of these ? are they any good ?
    Ebay item
    361017475182.
    any advice or experience welcome
    cheers
    Jan 2014
    Gloucester
    218
    16
    Matiz is offline
    Or what about a torque multiplier tool ? lorry wheel nut type thing ?
    Sep 2011
    Kings Lynn
    2,870
    332
    brading is offline
    Unless you can borrow a torque multiplier a torque I would go with a 3/4 drive bar and socket. This looks worth a shot
    3/4in Socket Extension And Bar In Good Condition
    autoholic.co.uk autoholic's Avatar
    Nottingham
    210
    11
    18
    autoholic is offline
    Have you tried the T4/5 Forum? VW T4 Forum - VW T5 Forum
    Rods 'n' Sods Junkie martnet'34's Avatar
    Nov 2009
    Stockport
    151
    21
    martnet'34 is offline
    special tool needed to hold the pulley to loosen and tighten (somthing like 120Nm then 1/2 turn) as you say they're effin tight, don't forget to replace the bolt and the diamond coated washer (i kid you not!!) etc or it will work loose and spin the lower pulley causing untold misery
    Jan 2014
    Gloucester
    218
    16
    Matiz is offline
    Cheers Martnet,
    I have ordered the pulley holding tool, should be with me tomorrow, then a 3/4 drive breaker with pipe on it I think will be in order.
    Yep new stretch bolt will be used.
    I assume it is a normal right handed thread ?
    T
    Feb 2010
    Selby north yorks
    1,910
    127
    rodster is offline
    We use Big Bertha for crank bolts, a 1 inch impact gun, even with that we have on times had to apply heat aswel
    TechnicalTom
    Nov 2009
    CORK IRELAND
    391
    9
    TECHNICALTOM is offline
    Yes it is right hand thread,I have a few VW s 2.4 2.5 , and have used 3/4 drive bar+socket plus the E Bay holding tool,last time I used an 3/4 drive extension bar that I "pivioted" on an axle stand.Not forgetting the 5 Ft. steel pipe.Do not be tempted to remove starter motor and wedge the ring gear !!!
    Jan 2014
    Gloucester
    218
    16
    Matiz is offline
    Well the pulley holding tool arrived and was used, resulting in success
    Crank bolt has been removed ! !
    Sep 2011
    Kings Lynn
    2,870
    332
    brading is offline
    That's good news now you have just got to get the bolt retightened to the correct torque
    1. Wanted crank pulley bolt ford 223 engine
      By fordf350camper in forum Stuff - WANTED
      Last Post: 02-10-2012, 21:26
    2. Rover 75 diesel crank pulley?
      By kapri in forum On Topic
      Last Post: 24-07-2012, 19:43
    3. Buick 3.8 V6 crank pulley bolt needed urgent!
      By alistair in forum Stuff - WANTED
      Last Post: 27-02-2012, 21:14
    4. Chevy V6 crank pulley needed
      By Farmer in forum Stuff - WANTED
      Last Post: 25-05-2009, 09:14
    5. SBF Alloy Crank Pulley
      By Lee in forum Stuff - WANTED
      Last Post: 20-05-2009, 18:13
