Waterpumps..............clockwise & counter-clockwise
Results 1 to 10 of 13
    Official RnS Addict falfasrevenge's Avatar
    Bristol
    1,051
    40
    5
    falfasrevenge is offline
    The BBC i've got in the '55 came from a scarab racing boat which had two 454 bbc in it.Mine,as it happens ran counterclockwise.Changed cam and rings etc and runs fine,if a little hot.Was mentioned today if i had the right water pump in as the impeller would be the wrong way.I know the serpentine pumps run differant but can anyone confirm one way or the other if the waterpump would be wrong? are marine bbc waterpumps differant ? or would it be as efficent ?
    Thanks
    F**k the Circus !!!!
    Col
    Heavy Oiler Col's Avatar
    Feb 2010
    berks
    2,502
    299
    Col is offline
    They are the same as car ones except they have a stainless steel backing plate and bronze impellor. They work either way.
    Was engine Raw cooled? This can cause the block to fill up with shale & rust so this might be the cause. If this is the case you need to flush the block with some thing called Rydlyme, It's designed for raw water engines & coolers.
    Rad flush won't work properly as its a different type of blockage than a car would suffer from. it's expensive but does the job. Fill the system with a mix, run engine, let it sit for a couple of hours, then flush with fresh water.
    Col
    Feb 2010
    berks
    2,502
    299
    Col is offline
    Bristol
    1,051
    40
    5
    Cheers Col,
    Flushed the engine with water from hose and also used airline with small pipe on through core plugs holes as did have some black,slimey stuff in it.
    Have you used Rydlyme ? Works out about £10 per litre so wondered how much is needed ?
    Col
    Feb 2010
    berks
    2,502
    299
    Col is offline
    Yes I use it all the time to clean Marine intercoolers, oil coolers, and raw cooled engines etc: The beauty is it clears out the calcium & mineral deposits that you just don't get in a road engine.
    Cost wise, only worth doing if engine was raw cooled (ie) had seawater running through block. If you're not sure, have you got a photo of engine as removed from boat you could post?
    2litre would be plenty, just let it stand for at least 2 hrs.
    I will post a couple of pics later to show you how good it is.
    Bristol
    1,051
    40
    5
    No ideal as the engine was on the floor....... But would a boat with nearly 15l (two 454's) be inland ?
    Black gup was similar to when normal radiators are removed
    Col
    Feb 2010
    berks
    2,502
    299
    Col is offline
    Here is a before & after of an oil cooler I did with Rydlyme a couple of weeks back.
    Scarab is a beast of a boat (remember Miami vice?)
    Can you remember what colour it was painted as different marinisers used different paint.
    It was most likely Mercruiser being a Yank boat (black engine)
    Volvo Penta was Orange and Crusader-Palmer blue.
    Crusaders are freshwater cooled by default. The others it was an option.
    Bristol
    1,051
    40
    5
    Definatly painted blue col.....still got the inlet and seized alternator somewhere
    Col
    Feb 2010
    berks
    2,502
    299
    Col is offline
    Thats a Crusader Palmer (should have twigged when you said reverse rotation) Almost certain it is freshwater cooled originally. Have a look at the back of the waterpump. Has it got a stainless plate or mild steel? You can use a magnet to check.
    Col
    Feb 2010
    berks
    2,502
    299
    Col is offline
    Your engine would have looked like this in the boat.
    The cylinder running transversly across the back of the engine is the heat exchanger (boat radiator)
    You can see it clearer here (note the rad cap on top)
    So really yours should have been freshwater cooled originally. It won't hurt to put rydlyme in but it sounds like it doesn't need it assuming it was FW cooled.
    1. WHEELS..10 x 15s.. US.Ford...and Rev Counter....
      By BRIT DIGGER in forum Stuff - WANTED
      Last Post: 18-01-2010, 09:40
    2. 1970's Stewart Warner Amp gauge
      By Blue in forum Stuff - FOR SALE
      Last Post: 18-12-2009, 13:54
    3. Wiring an Autometer Rev counter ?
      By Tarmac Tanner in forum Tech Discussion
      Last Post: 28-09-2009, 15:39
    4. rev counter settings
      By vin likes diesel in forum Tech Discussion
      Last Post: 13-06-2009, 07:50
    5. Rev counter, Hot Rod book & magazines
      By Special When Lit in forum Stuff - FOR SALE
      Last Post: 12-06-2009, 17:33
