Whats wrong with my Fu***ng brakes (fixed)
Likes Likes:  1
Results 1 to 10 of 32
    dek
    Rods 'n' Sods Junkie dek's Avatar
    fife scotland
    356
    5
    dek is online now
    single circuit system , master cylinder, drums on all four corners, no servo
    pump pedal and its fine press it again five seconds later , nada straight to the floor , bled all four corners, same result
    binned the master cylnder for a new one , bled all again plenty fluid through all corners no air bubbles, same result,
    any clues seems like its air but its been bled fine upteen times, with zero bubbles in the fluid
    help , its driving me mad
    highly experienced bodger draguar's Avatar
    Feb 2011
    Brentwood Essex
    260
    20
    draguar is offline
    Did you bench bleed the master cylinder?
    dek
    fife scotland
    356
    5
    dek is online now
    nope
    22,933
    Under the floor m/c ? Original source of m/c ? Has it always been like this ( could be undersize ) ?
    dek
    fife scotland
    356
    5
    dek is online now
    yes m8 under floor, car been on road 20 yeas , no built by me , has a hyster forklift master on it ,same as one thats been on it for years
    Feb 2011
    Brentwood Essex
    260
    20
    draguar is offline
    I had loads of issues with mine till I took it off and bench bleed it first you put blanks in the port where the pipe comes out of, mine come with plastic ones, grip it in a vice then fill will brake fluid and pump the cylinder with w wooden dow or something similar and keep pumping till no air comes out into the reservoir and it gets impossible to move the cylinder any more, then refit and bleed as normal
    Also make sure all your drums are adjusted correctly and the wheel cylinders are not weeping but I would presume you have already done that
  9. Likeshotrodboy liked this post
  10. #7
    22,933
    In that case it sounds like bench bleeding is the way to go . Obviously I'm assuming it has been ok in your ownership up to now ? Then as it's underfloor I'd vacuum bleed it rather than pressure or trad method manually.
    With an all drum set up I'd expect the m/c to have internal anti bleed back valving to prevent the strong drum brake springs returning all the fluid .
    I don't know if that is standard on the forklift cylinder ? Otherwise I'd be fitting adional residual pressure valves inline.
  11. #8
    Jul 2009
    three holes, wisbech, cambs
    4,955
    930
    352 kum is online now
    got a flexi hose swelling under pressure or a cracked drum
  12. #9
    Care in the Community WagonMan's Avatar
    Stoke on Trent
    2,674
    508
    WagonMan is online now
    I would say it needs residual valves to stop the fluid being pushed back from the cylinders, if it has these fitted then the m/c could possibly need bench bleeding.
  13. #10
    12,628
    all the above and....... get a pump up garden weed sprayer. fill with brake fluid and 'back' bleed 'in' through the bleed nipples to push the air back out though the master cylinder. it's messy but has always worked for me on stuff that just won't bleed whatever else i try.
