where to get handbrake cable nipples.
Results 1 to 8 of 8
    Jun 2011
    Barnby. Suffolk
    128
    54
    top cat is offline
    I've got a pair of Volvo handbrake cables that I have shortened to go on my Pop, these go on a Subaru hand brake. The hand brake end of the cable was already cut off [I presume] as they where to be fitted to another application. This meant that I could slide the cable out, pull the fitting off the axle end of the outer casing cut to length and glue the fitting back on. What I'm after is a pair of 10mm. nipples to go on the end of the cable. I've seen 6mm & 8mm but no 10's any ideas where I can get hold off some.
    Official RnS Addict MikeS's Avatar
    Mar 2010
    Leighton Buzzard
    3,251
    207
    MikeS is offline
    Try here Speedy Cables
    Jun 2009
    bromley, kent
    1,403
    396
    prostreet70gto is offline
    find a pair of shouldered bolts that fit the hole where the nipple go, drill a hole in the shouldered part and cut off the thread and the head then solder them on ....job done
    Rods 'n' Sods Junkie TrOjAn's Avatar
    Jan 2013
    Basildon - Essex
    111
    22
    TrOjAn is offline
    Quote Originally Posted by prostreet70gto View Post
    Would solder hold ok? theres a lot of pressure on that cable ( big arms )
    TrOjAn
    Jun 2009
    bromley, kent
    1,403
    396
    Quote Originally Posted by TrOjAn View Post
    TrOjAn
    its always worked for me, but as with any soldering it must be clean. I was making a general comment about drilling a hole, the actual thing i would do is...drill a hole just big enough for the cable, then from the othe side i would re drill with a larger drill to half of the depth of the first hole. feed the cable through the small hole, splay the end of the cable, fill the bigger hole/end of cable with solder, and cut/clean off the excess piece. As long as its clean, it has been soldered correctly and is done right it will be fine. The solder wants to be silver solder which is harder than regular wiring solder
    Rods 'n' Sods Junkie nelly's Avatar
    Jul 2011
    Gloucester
    209
    15
    nelly is offline
    I used these 2 Solderless Nipples 8mm Motorcycle Scooter Quad Car Throttle Brake Clutch etc | eBay Then folded back some of the strands and got the mig welder on them to finish it off
    Procharged 406ci 92 Camaro
    Jan 2013
    Basildon - Essex
    111
    22
    TrOjAn is offline
    Cheers.. I think Ill try that.. nice tip.
    TrOjAn
    Gym Junkie chrisvs's Avatar
    Jan 2011
    Hitchin
    6,213
    125
    chrisvs is offline
    TrOjAn
    Many years ago I did that for some cables (front brake ,clutch and decompression lever) I made up for a BSA trials bike, as already mentioned making sure the cables are meticulously clean is key, the cables I used were a bit greasy/oily so used a degreaser before tinning but it worked a treat.
    1. jag handbrake cable
      By homer in forum Stuff - WANTED
      Last Post: 06-08-2010, 21:00
    2. Replies: 0
      Last Post: 31-07-2010, 18:11
    3. Where to get a 350 SBC for a rebuild?
      By zephyr in forum On Topic
      Last Post: 07-07-2010, 15:20
    4. Handbrake Cable - Jag IRS
      By THE POP SHOP in forum Tech Discussion
      Last Post: 20-10-2009, 16:59
    5. Number plates. Where to get them
      By Paul Y in forum On Topic
      Last Post: 04-09-2009, 23:10
