Where to stick the vacuum for the servo.... Edelbrock
Results 1 to 5 of 5
    Rods 'n' Sods Junkie Pepsi Max's Avatar
    Jan 2010
    Kent mainly
    441
    18
    Pepsi Max is offline
    Anyone...help needed
    Got 500 Performer carb on performer manifold....have option to put servo pipe in the manifold or the bottom of the carb...which is better.
    No Pcv, that will be blanked off as will the vacuum for the distributor as there is no advance on the Mallory fitted
    Thanks
    Paul
    Politicians and diapers have one thing in common. They should both be changed regularly, and for the same reason.
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    You want manifold vacuum for a servo, either from the south side of the carb butterflies or from the inlet manifold itself.
    Stuart.
    My Intro
    Jan 2010
    Kent mainly
    441
    18
    Yep, got both options...the carb and the manifold have threads. The servo is into the manifold at the mo, but Ive just renewed the carb, which has a hole also.....just wondering if there was any advantage. Have 2 holes, one threaded union and one plug, so the choice is mine.
    Paul
    London Heathrowish!
    7,721
    46
    Plumpcars is offline
    As was said earlier either works. Mate has just put twin Edelbrocks on his and the clearance between that rear carb take off and the dizzy is very tight. If you're only using a single carb it works fine though.
    Official RnS Addict Discododge's Avatar
    Oct 2010
    Gwent South Wales
    1,419
    312
    Discododge is offline
    Here's a picture of the motor in my old Cougar. The servo pipe can be seen connected to the bottom of the rear carb and worked fine. When I had a single Holley fitted it was into the manifold, there was no differance to way the brakes worked. Hope this helps, Mark
    the difficult takes time, the impossible takes a little longer
    1. Where's all the rods for sale ?
      By WB54 in forum On Topic
      Last Post: 22-09-2010, 20:53
    2. Where be all the Kustoms?
      By Bel Air Lugosi in forum On Topic
      Last Post: 17-08-2009, 22:28
    3. Where does all the power come from ?
      Last Post: 07-08-2009, 08:56
    4. where's all the history gone?
      By ken57 in forum On Topic
      Last Post: 18-06-2009, 19:57
    5. where's a good place for tyres???
      By paul in forum On Topic
      Last Post: 24-04-2009, 12:26
