Why didn't it explode?
Results 1 to 10 of 20
    Official RnS Addict zephyr's Avatar
    Banbury
    590
    91
    zephyr is offline
    QuestionWhy didn't it explode?
    Had a fuel leak - ended up pulling the sender unit out. The fuel gauge needle has always jumped around from zero up to where it should be. There's a brassy metal strip about 1/4" wide from the potentiometer up to inside of the flange that bolts to the tank where it attaches to an insulated bolt that the wire to the gauge connects to. The metal strip had broken and was making and breaking contact with the bolt, hence the needle jumping around.
    Soooo.....an electical circuit was constantly making and breaking, which must surely have resulted in a spark inside the tank!!??!? Near the top, above the level of the fuel, where there would have been air and petrol vapour. So how come it didn't just go bang? As the tank is right behind the back of the seat, I reckon I'd have noticed! So was I lucky or am I missing something?
    Official RnS Addict chris's Avatar
    Melksham Wiltshire
    1,081
    278
    chris is offline
    very lucky i reckon
    Flange Dealer Paul G's Avatar
    Derby , UK
    642
    57
    Paul G is offline
    Probably all fume & very little oxygen , or the broken bits too dull to make a contact. Still damned lucky though!
    Banbury
    590
    91
    zephyr is offline
    Spose I'd better fix it then! Seriously though, the truck's only had a gerry can of petrol at a time and it's been started and left running while I try and stop it leaking vital fluids all over the drive lots and lots of times. Surely I'm not that lucky? There's bound to have been plenty of air in there. Anyone know what ratio of air to fuel is needed for ignition and normal atmospheric pressure?
    The Butty Run - Warwickshire breakfast meet, 1st Sunday of every month
    http://butty-run.com
    Cheltenham
    4,076
    601
    fozwanger is offline
    You generally find that the air/furl ratio in the tank is too high, the "atmosphere" in the tank will be above the UEL (upper explosive limit) and therefore there will not be enough oxygen to sustain a fire, hence no bang. On the other hand, if there is too much oxygen, there is not enough fuel to feed the fire, this will be below the LEL (Lower Explosive Limit)The "explosive" band is roughly between 8 - 15% fuel to air ratio (God, I'm sad)
    Also, fuel is conductive ( the fuel companies add additioves) as fuel generally tends to build up a static charge when tanks are charged / discharged (for refinery and transportation purposes) so they need to be conductive to disipate the charge. (Am I boring you yet?)
    finally, your fuel gauge will probably be of the potentiometer type, only Eddy current, V low voltage, just measure the difference across the device.
    And remember, it's only "explosive" if the mixture is "contained", it'll just burn really unimpressively in open air.
    I think I need to get out more (time for a career change too, been in fuel testing and on fuel farms for far too long......... :-$
    Lol
    Solihull, West Midlands.
    78
    Mart is offline
    You'd crap yourself if you thought too long about the in-tank pumps. They have electric motors running submersed in the fuel.
    Mart.
    Cheltenham
    4,076
    601
    You'd crap yourself if thought thought about a lot of the things you use everyday, washing machines and kettles and electric showers, hmmm, electric and water, now there's an accident waiting to happen.....
    Rods 'n' Sods Junkie pop-dreamer's Avatar
    Location location, Walton Nr. Street, Nr. Glastonbury. Som.
    152
    13
    pop-dreamer is offline
    Quote Originally Posted by fozwanger View Post
    Lol
    If that was boring, then I am boring too, because I found it quite interesting!
    North Yorkshire
    355
    25
    FlatheadFordV8 is offline
    YouTube - Nutter sets fire to a petrol pump
    Notice how when the static spark lights the vapour, it's a big floppy flame, not a small blue one, and there is no BANG.
    It probably only lit because it mixed with the extra air outside the tank.
    Still a brown undergarments moment though!!!!!!!!!!
    London Heathrowish!
    7,708
    46
    Plumpcars is offline
    Just had a fuel hose split on the 34 whilst driving it. I smelt fuel but had just filled up and it always smells a bit on rh bends for the first few miles so wasn't worried. Holley comp pump so high pressure over the right hand exhaust manifold for at least 4 miles. Pulled into my garage adjacent to my brother working on his Panhead. He was screaming at me to get it back out as he didn't want his bike destroyed!
    Still not sure why that didn't go up.
    1. 200mph both wheels explode
      By 29pu in forum Chat
      Last Post: 16-04-2010, 17:15
