Will a residual pressure valve help..
Results 1 to 10 of 36
    Jun 2012
    Cambridge
    251
    Ian r hall is offline
    My cortina has regular ford m16 calipers at the front and mk3 escort discs at the Rear, has a single circuit 0.7mm master cyl. Ive bled it many times and am certain there's no air. Still I have a poor pedal and little stopping power. If I clamp off the rears I get a good pedal and pretty good(front only) brakes.
    I can't understand what's happening, would fitting a proportioning valve or a 2lb residual pressure valve help or do I need a bigger master?
    Thanks
    Ian
    Jun 2009
    romford essex
    2,735
    827
    296moon is offline
    have a look here, might help you, https://www.rodsnsods.co.uk/forum/top...ylinder-414009
    Gym Junkie chrisvs's Avatar
    Jan 2011
    Hitchin
    6,213
    125
    chrisvs is offline
    Think you've got your MC bore size wrong, maybe 0.7 in
    Paradise is full of idiots who believe it exists - Georges Wolinski
    I Think Therefore I Am - René Descartes
    www.nothingbeingadvertisedhere.com
    Herts. and ahead of Larry :)
    2,581
    34
    chevy2 is offline
    If you've got poor stopping power now with a 0.7" master, by going to a larger bore one will only give you a higher pedal and with even less stopping power than you have now,
    you probably have an issue with your current setup to deal with,
    you may still have air in there,
    a residual valve is only needed to retain a small amount fluid pressue in the system without drain back to the master if the master is lower than the calipers or wheel cylinders, ie with an underfloor master cylinder.
    Jun 2012
    Cambridge
    251
    That's what I figured too, it's just that I've tried everything I can think of, have bled it countless times and there's no air. I've established the problem is at the back as I can remove the problem by clamping the hose off
    2,581
    34
    chevy2 is offline
    Not necessarily,
    clamp off the fronts and run through it and see if you get a similar pedal to when the rear system is clamped,
    its gonna be a better/higher pedal as you're now only feeding two calipers.
    Grown up? Never!
    Norwich
    2,069
    35
    chaley is offline
    The rear calipers are going to displace a lot more fluid than the old drums, so you are going to need a longer stroke M/C, not a bigger bore, that would just make for a harder pedal. I'm pretty sure that's how I did it on my old Anglia (it was along time ago )
    Chaley
    Tetanus
    Jun 2009
    Kent
    414
    Frankee is offline
    Are you sure the pushrod is long enough and displacing enough fluid when pressing the pedal?.
    Jun 2012
    Cambridge
    251
    Quote Originally Posted by chevy2 View Post
    Not necessarily,
    Yes, I clamped both fronts off and got a reasonable pedal, not as good as just fronts. Feels like there's a little air in the rears but I really have done everything and can't get any more air out!
    Jun 2012
    Cambridge
    251
    Quote Originally Posted by Frankee View Post
    The pedal doesn't go completely to the floor although it is very close. A longer pushrod will raise the pedal I suppose but I think brakes will still be poor
    1. What's a residual brake valve?
      By Ian r hall in forum Tech Discussion
      Last Post: 20-02-2014, 20:34
    2. Residual pressure valves
      By KoppaK in forum Tech Discussion
      Last Post: 26-09-2013, 18:14
    3. Egr valve help please
      By hogbloke in forum Chat
      Last Post: 18-03-2013, 17:53
    4. New dual circuit brake installation & residual pressure valves
      Last Post: 21-06-2012, 14:45
    5. Chevy power steering reduced pressure valve
      By 302zeph in forum Stuff - WANTED
      Last Post: 20-01-2011, 18:22
