wiring in a elec fan
Results 1 to 10 of 14
    Official RnS Addict 34 boy's Avatar
    southampton, ish
    575
    82
    34 boy is offline
    For reasons I am going to fit an electric fan, the question I want to ask is would you wire it staight to battery through a temp controller and let it run untill it cools down when engine is switched off or run it through the ign so when engine is turned off fan will cut off.
    Thanks
    LETS GO TRACTOR TIPPING !!!!!!!
    www.victorywheelers.co.uk
    Sep 2011
    Kings Lynn
    3,203
    464
    brading is offline
    IMHO I would run it through a temp controller, you would need to run it through a relay as well.
    southampton, ish
    575
    82
    34 boy is offline
    Hi brading yes both ways will be through a temp controller and fused just thinking when engine turned off let the fan run on or turned off with ing.
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    I would wire it via the ignition. The 16" fan on my truck takes 25A when it's running; for the same reason it's wired via a relay so that the fan's thermo switch doesn't take the fan's electrical load.
    Stuart.
    My Intro
    Gym Junkie chrisvs's Avatar
    Jan 2011
    Hitchin
    6,213
    125
    chrisvs is offline
    I'd wire it through the ignition with a relay, if you need it to run on after switching off use a delay timer like this one:
    12 volt Timer relay. Configurable time & delay on or off.: 74205
    Paradise is full of idiots who believe it exists - Georges Wolinski
    I Think Therefore I Am - René Descartes
    www.nothingbeingadvertisedhere.com
    Sep 2011
    Kings Lynn
    3,203
    464
    brading is offline
    This is how to wire it up with a relay not sure how you would add in the Timer relay though. As for a timer relay would look at a Durite 0-740-XX one think they might be cheaper.
    Official RnS Addict stu460's Avatar
    Jul 2011
    Cheshire
    1,792
    66
    stu460 is offline
    Unless you run an electric water pump, running on when the ignition is off won't do a great deal for the engine unless you get some syphonic flow. Better to wait while it's idling and let the fan switch off before turning the ignition off.
    southampton, ish
    575
    82
    34 boy is offline
    Thanks all, yes brading thats how I was going to wire it in, the thermostat wont have a big amp draw so should be ok to wire into the ign feed, found a 70 amp relay new lying around so will use that, all other parts ordered just waitng for them to turn up.
    As I run a diymino I did not want the fan to run on after switch off have small batt as well
    Rust Obsessive J1MMY's Avatar
    Swinetown
    642
    J1MMY is offline
    Please excuse the hijack but I was nosing through with the intention of asking about electric fans - may I ask what engine you've got and fan/rad size?
    9,194
    1774
    blackpopracing is offline
    Interested in the timer delay as I'm running mine direct from battery supply at present and it always runs for about 5 mins after parking up with around a 25A draw - not too good for the battery!
    I'd like to limit it to 60 seconds or 2 mins ideally max - is there a delay relay available for these periods?
    How would it wire in to the circuitry above?
    1. wiring elec fan on my rad
      By panzer 4 in forum Tech Discussion
      Last Post: 26-06-2014, 19:22
    2. kenlowe elec fan and thermo fitting,
      By panzer 4 in forum Stuff - WANTED
      Last Post: 02-06-2014, 07:38
    3. flex-a-lite black magic elec fan kit universal
      By GT350 in forum Stuff - FOR SALE
      Last Post: 26-11-2013, 14:22
    4. electric rad fan wiring kits ???
      By lambretta_ash in forum Tech Discussion
      Last Post: 07-10-2012, 21:39
    5. fan wiring promlem
      By scrapyarddoguk in forum Tech Discussion
      Last Post: 11-01-2012, 20:45
