worst skimmed camel hump heads ever seen... unskimable?
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 71
    Rods 'n' Sods Junkie TheWebDesignCompany's Avatar
    Jun 2016
    Southend on Sea
    224
    TheWebDesignCompany is offline
    Ive been having some overheating issues, and finally the head gasket blew. So I've had a mechanic strip it down and remove the heads so they can be skimmed and refitted. But he said they are the worst skimmed heads he has ever seen, you can clearly see and feel little lines on the heads and this was causing the overheating and water ingress.
    Anyone ever experienced this? is it possible to have unskimable heads? Has anyone ever had heads that couldn't be skimmed?
    Im hoping mine are not unrepairable as I'm stone broke and can't afford new heads. (Even though I dream of a nice set of Aluminium AFR 180 heads, but then I would need a new manifold and new rocker covers etc...)
    iver, bucks
    74
    43
    Mango man is offline
    all heads are skimmable its just a case of having the correct machine and know how, I think your mechanic means the finish after machining is too course or the tool used was blunt , or in laymans terms the finish is s--t, have a word with a local machine shop and they'll sort them for you.
    Jun 2016
    Southend on Sea
    224
    Well that is encouraging, thanks.
    Is it not possible to not have enough meat left on the heads for them to be skimmed again?
    up north
    1,989
    35kid is offline
    Quote Originally Posted by TheWebDesignCompany View Post
    it is possible not to have a lot meat left on them but they would need to have had a an awful lot of material removed previously. im sure they would probably be ok to have them cleaned up.
    Rods 'n' Sods Junkie rockstar's Avatar
    Sep 2014
    Warwickshire
    137
    9
    rockstar is offline
    Yes it is possible to have heads that are un skimmable,really depends how many times they have been skimmed,what is the thickness between water jackets and or oilways,plus check on valve stand down.
    Dave
    Jun 2016
    Southend on Sea
    224
    Im taking them to be checked on Monday and skimmed if they can be done.
    In the mean time if anyone has a set of heads they want to sell... Let me know
    Stroker Kustom Jim's Avatar
    Bath
    4,734
    2611
    Kustom Jim is offline
    I would imagine doing a final cut skim as it were will remove very little unless they have other issues.
    A good miller will check em easy enough :-)
    Carroll Shelby
    Jun 2009
    Rayleigh Essex
    3,097
    278
    trevd is offline
    if they have been skimmed too much you may have problems with inlet manifold mating properly, if you skim the heads you should also skim the manifold mating surface look at this website for more info (end of page is a chart) a minor skim to remove imperfections should be possible. in the past I have used a sheet of glass and grinding paste to clean up minor imperfections.
    milling heads and intakes | Grumpys Performance Garage
    Jul 2015
    Elimbah, Queensland, Australia
    527
    1172
    HALLnRODZ is offline
    A mate had a Datto 1600 SSS head that I saw, It had been milled so often that only half the DATSUN logo cast on the side of the head was missing!! True story.
    They released a shim kit to suit those L series engines as the used to curl the heads a bit.
    Re the finish on the cast heads, I would think that they must have been REALLY bad as the gasket likes some marks the bed into. You can also use Hylomar gasket spray to enhance gasket sealing.
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    How close is the head surface to the inlet valve seat? This should give you a very good idea of whether there's potential for another skim. because of the angle of the valves, every time the head is conventionally skimmed, the machined surface of the head moves a lot nearer to the valve seats on the shallow side of the combustion chamber. By conventionally skimmed, I mean that the head will be set up on the mill with the machined head surface nominally parallel to the milling machine bed, so that that the same amount of metal comes off both sides of the head.
    Even if from the above, it looks like your heads have had a heavy skim, it may still be possible to wedge skim them, where the heads are set up tilted on the milling machine bed, such that more metal comes off the deep side of the combustion chamber than the shallow side. That's what's going on in this photo of 'an SBC head I prepared earlier' You can see here that the head face is close to the inlet valve seats -this late head was seriously warped.
    I've done this on several pairs of SBC/SBF heads now with .025" of "wedge" with a total cut of .030" and there's never been the fitting problem with the inlet valley that TrevD refers to, although if your heads have had heavy skim already, you may need to get the inlet manifold faces machined too because AFAIK, the heads I've done were as machined by the factory when I got to work.
    Stuart.
    My Intro
    1. Replies: 7
      Last Post: 22-02-2017, 16:03
    2. 40 dcnf carbs transit springs sbc camel hump heads
      By movinghotods in forum Stuff - FOR SALE
      Last Post: 13-03-2013, 21:19
    3. chevy camel hump heads
      By railway rob in forum Stuff - FOR SALE
      Last Post: 23-11-2012, 13:41
    4. funniest thing ive ever seen
      By 67 satellite in forum Chat
      Last Post: 24-06-2010, 17:28
    5. Cleverest Burglar I've ever seen!
      By capriac in forum Chat
      Last Post: 05-06-2010, 10:57
