XJS IRS Differential Swap
Results 1 to 9 of 9
    Keep on Trucking... F100Jay's Avatar
    Apr 2015
    South wales
    535
    11
    130
    F100Jay is offline
    Can anyone confirm the rear diffs in the jag IRS are all interchangeable?
    I've got a 2.88 in my IRS at the moment. My engine and box I'm running originally came with a 3.62 rear end. I'm concerned its not gonna do a burnout etc because of the 2.88 so thinking of changing it out now before final paint and assembly.
    Also can anyone confirm that 3.31 is the highest ratio available?
    Cheers,
    Jay
    Official RnS Addict Phunkie Hiboy's Avatar
    Lindford
    1,014
    Phunkie Hiboy is offline
    Click on this link, there's a comprehensive list of all ratios for Jag IRS
    Jag diff ratios
    Built without compromise by the more luck than judgment method
    Dec 2012
    winsford
    339
    221
    boblester40 is offline
    Info here
    Dana 44 into a 19 spline Salisbury Jaguar IRS conversion parts. | phrog
    If you change the carrier to a auburn LSD or similar then you can put a standard DANA 44 ring and pinion in it and thus any gear ratio you want , I did this with mine and run a 4:11 gear
    Apr 2015
    South wales
    535
    11
    130
    F100Jay is offline
    Quote Originally Posted by boblester40 View Post
    Info here
    Awesome info. Cheers for that. I think that's what way I'll go.
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Not completely straightforward to change from a 2.88:1 Salisbury 4HA CW & P. The 2.88 crownwheel is larger than an "ordinary" 4HA one, so the diff case is machined to ensure that the pinion centre distance is greater than the 2.625" of all the other 4HA (and Dana 44, which are basically the same axle) You can use the 2.88 diff in "ordinary" 4HA case (the diff should be a PowerLok LSD) but to use any lower (numerically higher) ratio you will need a spacer between the diff and the crownwheel. Here's one I prepared earlier:
    This picture shows why the spacer is necessary. The diff on the left is a PowerLok which had a 2.88:1 crownwheel fitted, the one on the right is a standard 4HA diff which had a 3.3:1 crownwheel fitted.
    Dana 44 internals will fit a 4HA case and vice versa. However, when mixing the bits you need to be aware that only late Dana 44 Crownwheels (called Rings in Americanese) had 7/16" boltholes, early ones were 3/8" -the holes in 4HA diffs & Crownwheels have always been 7/16" AFAIK. Dana 44 pinions have 27 splines at the yoke end, 4HA ones have 10 splines. Being American they use an American style yoke, the only exception I know of is the Isuzu Rodeo rear axle, which uses a European type drive flange with the Dana 27 spline fitting. Finally, if you decide to use a Dana 44 diff, make sure to order the early type with 19 spline halfshaft fitting; the later ordinary/early heavy duty ones have a 30 spline output.
    HTH.
    Stuart.
    My Intro
    Dec 2012
    winsford
    339
    221
    Very informative , However its much simpler just to buy the auburn carrier and the correct gears from the states , the 4.11 gears are available in deep and shallow versions to suite each type of carrier , thus eliminating the need for spacer rings and additional faffing .
    I did this with mine and everything dropped into place perfectly , also you upgrade the weaker jag LSD for a unit suitable for much higher torque
    Dec 2012
    winsford
    339
    221
    Picture of my XJS diff with the new auburn carrier and gears , simples
    South Norway
    200
    staleg is offline
    I have an original Jaguar IRS with ratio 4,09:1.
    Good judgement comes from experience, and a lot of that comes from bad judgement.
    South Norway
    200
    staleg is offline
    Available in the JX6 2,8L produced from 1968-1985.
    1. Jaguar xjs irs with lim slip diff
      By hurnleft in forum Stuff - FOR SALE
      Last Post: 02-11-2016, 17:02
    2. xjs IRS dims
      By johnchisholm in forum Tech Discussion
      Last Post: 23-05-2015, 20:28
    3. Jaguar IRS xjs rear coil springs
      By Deets in forum Tech Discussion
      Last Post: 26-02-2015, 16:36
    4. JAG XJS IRS Diff speed sensor
      By radiogareth in forum Stuff - WANTED
      Last Post: 27-07-2014, 12:16
    5. Irs tie bar buy or swap
      By gazzmyster in forum Stuff - WANTED
      Last Post: 27-05-2013, 10:58
