Zf4hp24 electronic gearbox
Results 1 to 2 of 2
    Cheltenham
    4,076
    601
    fozwanger is offline
    Has.anyone run a zf4hp24 without an ecu or another box?
    I want to run without the ecu and just use paddle shifters to operate the ds. You can use R N and D (in third) without 12v power.
    I'm trying to find out about line pressures and the lock up function on the 3rd solenoid. I've come up with a solution to run the box as a sequential box with paddle shifters but need to understand the effect of line pressures and why I'd need to run the solenoid psych with a pen signal.
    Also, jag used them, as far as I can discover the cases are all the same, just bell housing and tails hafts are different. Would anybody know if the input shafts are the same length too?
    Jef
    12,520
    hi jeff, from what i found out the x300 with a 3.2 straight six had the non electronic version (4hp22) which needs no 'majic' to work. the 4hp24 that you have was behind the 4.0 from memory. maybe source the 3.2 box instead? neil.
    1. Four speed gearbox. Chevy pattern
      By Mad Mark in forum Stuff - FOR SALE
      Last Post: 22-01-2012, 16:38
    2. Electronic circuits?
      By col33 in forum Chat
      Last Post: 09-06-2009, 13:58
    3. dodge dart mopar small block auto gearbox
      By grubster1433 in forum Stuff - WANTED
      Last Post: 05-06-2009, 17:00
    4. Pinto electronic distributor
      Last Post: 04-06-2009, 20:17
    5. Gearbox ecu
      By Evil McNasty in forum Tech Discussion
      Last Post: 23-05-2009, 10:07
