zodiac coil spring
Results 1 to 10 of 15
    Official RnS Addict cozmic's Avatar
    isle of wight
    1,079
    cozmic is offline
    zodiac coil spring
    Hi all need your help again I am in the process of getting new coil springs made up for my zodiac problem is I need to know how the ends are finished ie- ground flush or butted up or what ? any help as always greatly appreciated a picture would be even better (before anyone says I cant see clearly on mine and I cant take it apart as its on the road
    Jan 2011
    harrogate
    301
    17
    pete cook is offline
    Hi,the last coil at each end is butted up to the next and the ends ground flat the same as normal coilover springs.What is the id of the springs,if they are 2.5 in you can get them off the shelf i think from Rally Design Cheers Pete
    isle of wight
    1,079
    cozmic is offline
    Hi Pete no they're way bigger than 2.5" id they are about 5" id are we sure how the ends are finished as I need to get a pair made and the supplier needs to know
    Jan 2011
    harrogate
    301
    17
    I,m ,almost sure when i took the ones off the consul they were the same as normal coilover ones ,i,m sure the seats are flat.Have a look at the bottom seats you should be able to tell .Pete
    isle of wight
    1,079
    cozmic is offline
    The spring pan has a recess for the spring tail to sit in but the manufacturers aren't happy to make a spring until they know for definite how the ends finish
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Try calling a firm called Tested Spring in Oldbury. They may know. They will also make them.
    Spring Manufacturer - Tested Spring - Oldbury, West Midlands
    Or failing that, send a PM to Enfoman on here. Seeing as he runs a firm called Zodiac Motor Spares, I would imagine he will know.
    isle of wight
    1,079
    cozmic is offline
    Still after positive info on how the ends are finished if anyone can help
    many thanks
    Charlie
    Mar 2010
    Stevenage
    546
    281
    rovertenrod is offline
    Just looked at mine and the answer is yes and no. bottoms are left as is.and the top is ground flat.
    isle of wight
    1,079
    cozmic is offline
    Hi rovertenrod thanks for that so is the bottom "just bent up to meet the coil above it"
    Mar 2010
    Stevenage
    546
    281
    I haven't taken them off the struts, but thats what they look like. I have the struts here only as I have "borrowed" the hubs from them to convert my HC viva front end. you're welcome to the struts and callipers if they're any good to you?
    Bottom
    They are in better condition than the photos show although callipers would need rebuilding.
    1. Coil Springs for JAG IRS what poundage?
      By piransurfer in forum Tech Discussion
      Last Post: 17-11-2010, 08:40
    2. a pair of coil springs
      By xr8 in forum Stuff - FOR SALE
      Last Post: 31-10-2010, 17:02
    3. coil spring rate
      By highlandrodder in forum Tech Discussion
      Last Post: 16-09-2009, 07:09
    4. reliant scimitar rear coil spring retainer
      By ThomasHarris in forum Stuff - WANTED
      Last Post: 07-08-2009, 21:40
    5. choppig coils springs
      By 56 AUSTIN in forum On Topic
      Last Post: 26-07-2009, 10:29
