Zodiac dizzy
Results 1 to 3 of 3
Thread: Zodiac dizzy
    Official RnS Addict cozmic's Avatar
    isle of wight
    1,079
    cozmic is online now
    Zodiac dizzy
    Hi all just fitting a new dizzy on my Zodiac and the old cap don't look right to me can someone post up a picture showing what leads go where Ie which dizzy cap terminal goes to no1 (front cylinder) cheers all Charlie
    Jun 2010
    Hampshire
    73
    Piggy is offline
    Charlie, Put the dizzy in (it will only go one way) without the cap. Fit the rotor arm. Turn the engine by hand until 1. the timing marks are aligned and 2. the front two valves are both closed (rocker arms are both loose). While turning the engine check the direction of rotation of the rotor arm. Put the cap over the dizzy and see which HT outlet port the rotor arm is pointing to. That is No 1. From there the firing order is 5, 3, 6, 2, 4, 1. That will be good enough to start the motor and you can then time it properly however you normally do it - with a light, by trial and error whatever. HTH Bob
    isle of wight
    1,079
    Well the ol girl lives again......... Crikey what a mess though the dizzy has been set up way off so come the weekend I.l reset it all as it should be......................good to get her running again though, thanks for the help saved me loads of strife
    1. Tacho on HEI Dizzy ?
      Last Post: 07-06-2009, 13:09
    2. Mk3 Zephyr Zodiac Gear Ratios?
      By FlatheadFordV8 in forum Tech Discussion
      Last Post: 23-05-2009, 15:02
    3. Mk2 Zodiac bits
      Last Post: 22-05-2009, 23:23
    4. zodiac mk2
      By pompeypaul in forum Stuff - WANTED
      Last Post: 05-05-2009, 05:36
    5. zodiac mk2
      Last Post: 30-04-2009, 19:43
