Zz502 flexplate smashed
Results 1 to 9 of 9
    LONDON
    106
    15
    VALET 10 is offline
    i have broken the teeth on my flexplate 3 times, Had a new high torqe mini starter fitted about 100 miles ago. Does anybody know the reason ?
    S.E London
    5,697
    510
    vince-305 is offline
    Poorly adjusted starter ??????
    Bit'z 'N' Piece's
    Banned
    Nov 2010
    BRITAINS FASTEST STREET LEGAL VAN HEAD QUARTERS
    4,329
    388
    Fordson Van is offline
    Starter dog to flywheel ratio wrong???
    23,081
    Quote Originally Posted by vince-305 View Post
    poorly adjusted starter ??????
    x2
    May 2011
    Hertfordshire
    2,499
    7
    Adam Sayers is offline
    Are you putting the flex plate on the right way round?
    Starter to flex plate clearance should be checked.
    Also are you using the correct knurled starter bolts. IMO it's important to use these as they take up all slack in the bolt holes. regular bolts wont do this and will allow movement no matter how tight you do them up.
    1955-56-57 Chevy new and used parts always available from www.randrhotrodimports.co.uk who I'm proud to have sponsor my '57 Chevy race car. 9.3 @ 155.8 mph / 0-60 = 1.47 seconds! Street legal :-)
    23,081
    Just jogged my memory, also check starter motot bolts lengths and those all th way around the bellhousing in case one is protruding too much and catching .
    S.E London
    5,697
    510
    Quote Originally Posted by Adam Sayers View Post
    Also make sure you get the right ones as Adam says .......... but i brought some that were listed for a sbc ............. but were too short
    Im not a lover of the mini starters as they dont allow fitting of the steady bracket and on a few of the mini's you can also adjust the starter on the mounting block as well as using the shims
    Bit'z 'N' Piece's
    LONDON
    106
    15
    VALET 10 is offline
    Im using the correct starter and the bolts that came with it also its shimmed ?
    Banned
    Nov 2010
    4,329
    388
    there a small drain plug on some converters and the flex plate has a hole cut out into which the plug sits,quite easy not to line it up and your plate will not sit square so mis aligning the dog..
    1. rover/th400 flexplate
      By ELECTRIC20 in forum Stuff - WANTED
      Last Post: 02-12-2010, 12:01
    2. mustang 2 flexplate
      By maz5700 in forum Stuff - WANTED
      Last Post: 10-11-2010, 15:49
    3. how do you tell a 28oz from a 50oz flexplate?
      By rootesix66 in forum Tech Discussion
      Last Post: 04-08-2010, 09:52
    4. chevy flexplate 168tooth
      By tatuu in forum Stuff - WANTED
      Last Post: 21-05-2010, 23:11
