I saw one the other week.
Bloke had a sheet of plastic.folded it in four,cut a bit out of it,which transpired to be a circle.
Then put it over the rim and it sat just behind the rim. Took about 2 minutes.
The video that I can't find,prob shows it better than I explained
Hidden Content | Hidden Content | Hidden Content | Hidden Content | Hidden Content
Cool, thanks for sharing, I was planning on a bit of a tidy up of mine this winter and was thinking along the same lines as a temp fix until I can afford get them powder coated in the future.
The critical thing must be able to deflate the tyres completely enough to get the cards/masking in, which I suppose means you need access to a compressor/air line on the return journey.
I roughly mask up and use Liquid masking film with a paintbrush up to the wheels edge. When I was a kid I used grease instead of LMF, just wipe off when paint is dry
