shrinking a 55 chevy steering wheel.
Results 1 to 10 of 10
    Sep 2009
    Norfolk
    367
    23
    Tiddytime is offline
    I recently fitted power steering on my 55 chevy, and always
    struggled with the none power it used to have, so I then
    decided to shrink the 18" steering wheel down to a 16",
    I also did this to my 58 brookwood last year, I cut the outer
    ring off keeping as much of the outer plastic whatever material
    the cut through the outer mild steel bar and eased it in to 16"s
    then marked and cut off excess bar, welded outer together
    made a wooden jig to make sure wheel is central or true
    cut excess off the two spokes and welded it up,
    so not to much reshaping to do, wheel already had some
    age related crackes so fixed them to and repainted, horn
    ring still fits where it should and to the untrained eye you
    wouldn't even notice the difference, aftermarket steering
    wheels for these motors are mega expensive with the puchace
    plus shipping,p.s. much easier to drive with the lower rashio box
    and smaller wheel.
    Jun 2009
    romford essex
    3,056
    1332
    296moon is offline
    What did you use to repair cracks an joints?, also a pic would be nice.........................
    Mr Cadillac :-) Motorama's Avatar
    Buckinghamcestercostershire
    1,717
    11
    Motorama is offline
    you can buy 15inch tri chevy wheels off the shelf, i guess yours owed you a lot less done
    Looking for a 50s car, Cadillac, Buick, Pontiac, Oldsmobile, Chevy, cash waiting. Message me or call 07836 349356
    Sep 2009
    Norfolk
    367
    23
    Hello There 296moon, the material originaly used was probably injected
    into the mould,I don't know what it is but I used davids p40, its a mixed
    fibre glass that you use the same as you would p38 body filler, you just
    mix up what you want to use and put hardner with it, but to repair your
    crackes use p40, shamfer out the cracks down to the metal base and
    bevel the plastic material back a quarter to half an inch, rub down area
    around crack so its keyed and fill with glass fibre you might need to fill
    a couple of times,let harden and shape, you will get some pinholes with
    the p40 so fill pinholes with p38 filler, hope this info helps, can send picks
    of my steering wheel if you private mail me. cheers Richard,
    Rods 'n' Sods Junkie cymrodder's Avatar
    Feb 2011
    anglesey, north wales
    156
    cymrodder is offline
    I would think that a mould could be made up from M D F using a router and a trammel bar, and a couple of sizes of core box cutters ( round bottomed cutters) to accommodate the steering wheel frame and that a casting resin or a reinforced body filler type material could be used. The construction of such a mould would be fairly inexpensive but fairly labour intensive .
    Rods 'n' Sods Junkie 69 ford's Avatar
    Sep 2009
    East Yorkshire
    385
    19
    69 ford is offline
    Tiddytime, I have recently bought a 1959 Chevy Apache with a manuel steering box, and am looking to upgrade to power rack, the kits I am looking at from the states are around £900.00 that bolt directly to the beam axle, what would you recommend and what did you fit? any help will be much appreciated.
    nowhere
    7,303
    2464
    nobody is offline
    Quote Originally Posted by 69 ford View Post
    are you looking to bolt it to the beam youreself
    Sep 2009
    East Yorkshire
    385
    19
    69 ford is offline
    Possibly, I'm still exploring the options at the moment, it looks quite straight forward, but I know it never is- so may be giving you a call..
    nowhere
    7,303
    2464
    nobody is offline
    its fairly straightforward.
    youre steering is behind the axle.
    if you use say a rhd ford power rack as they sit in front.flip it over and use behind should make it steer the right way.you will prob need to extend the steering arms off the rack,and mix,n,match ends to fir whatever track rod ends youre going to use.
    you will need some sort of sliding joint.one of the big company,s,poss flaming river sell one,or ive used one off a modern car and adapted it to suit.all modern cars somewhere will have a sliding joint.either inside the column or a lower connecting shaft.
    doesnt matter how or where you mount the rack,as you wont get any bump steer
    Epy
    Official RnS Addict Epy's Avatar
    Orkney Islands
    1,095
    113
    Epy is offline
    Go electric, less hassle,no pipes to route.
  1. Replies: 3
    Last Post: 24-09-2018, 13:48
  2. Stretching & Shrinking Metal with common Tools
    By ProMetalShop in forum Tech Features
    Last Post: 31-08-2013, 01:00
  3. Replies: 0
    Last Post: 08-04-2011, 16:29
  4. 55 - 58 Chevy steering wheel wanted
    By Deuces Wild in forum Stuff - WANTED
    Last Post: 08-02-2011, 08:53
  5. Amazon steering wheel or steering boss
    By 302zeph in forum Stuff - WANTED
    Last Post: 28-08-2010, 20:10
