Hi guys, been busy building up this 532 bbt last couple of weeks, having been bitten before with cam/lifter issues and motor in vehicle decided to fabricate a start rig stand around the engine stand, 50mm box section for the main part, laser cut plate to locate starter, when I moved in here and I fitted a hot tub, I kept the frame thinking the metal may get used, so that’s the radiator frame/ struts, used v8 jag type bobbins for motor mounts fixed to 6mm plate. I had a Ford duraspark dizzy so am using that with a gm hei module for ignition, couple of gauges on a board with start button, ign switch, and fan switch, quickfuel 750 carb on top, made a basic throttle lever, sometime next week will finish off the last bits and oil/fuel and see what happens, all been well once I am happy will put it in the 53 F100. Dave
