58 chevy truck lap belts
Results 1 to 10 of 20
    Rods 'n' Sods Junkie pilky69's Avatar
    Apr 2017
    Kent
    136
    pilky69 is offline
    hi all
    im after some lapbelts for my truck.. both pieces of the belt need to go from floor mount through the bench seat back and clip together..i seem to be only able to find american makers or only one piece of the belt is adjustable?
    any ideas welcome or companys
    jon
    American Truck importer v8.jimmy's Avatar
    Nov 2012
    Bo'ness, Central Scotland
    11,729
    4846
    v8.jimmy is offline
    I've been told that lap belts are illegal in this country apart from a centre seat Jon.
    Apr 2017
    Kent
    136
    pilky69 is offline
    ok jim thats the reason maybe i cant find any..But has anyone got some fitted.
    Nov 2011
    suffolk
    6,150
    1453
    russ6120 is offline
    Car builder solutions do lap belts but you would be advised to make some mounts and fit proper 3 point ones with a lap in the middle if you can't do anything else
    I'm a grown up member now ! steveslittlelucy's Avatar
    Dec 2015
    Rudgwick
    97
    8
    steveslittlelucy is offline
    stitchmeister hot rod trimmer's Avatar
    gloucestershire
    4,481
    5721
    hot rod trimmer is offline
    cant beat these guys https://www.quickfitsbs.com/
    www.customcoachtrimming.co.uk www.trimshop.co.uk hot rod and custom interiors ......ring 01386 834454 for a quote on any simple repair to full build custom interior or email me [email][email protected]
    57 chevy interior https://www.youtube.com/watch?v=2z_qwE-LG_8
    Nov 2012
    11,729
    4846
    v8.jimmy is offline
    Quote Originally Posted by hot rod trimmer View Post
    excellent Chris and their site clarifies the laws as well, so lap belts are legal on Yanks up to 1972. They aren't a good idea but at least I know I wont have to change the lap belts when I do the first MOT on my '67 Mustang.
    23,736
    Err, really ?
    Not according to MOT rules
    Flow chart https://www.mot-testing.service.gov....4s05000104.htm
    Requirements ABC https://www.mot-testing.service.gov....4s05000109.htm
    I think they probably asked an MOT tester rather than looked it up. Testers often let illegal stuff go on Yanks because " It was like that from the factory "
    Official RnS Addict MikeS's Avatar
    Mar 2010
    Leighton Buzzard
    3,251
    207
    MikeS is offline
    It's easy enough to fit 3 point belts, I used Transit seat belts and put the top mount on the B post at shoulder level; mine has the big rear window.
    I made the top mount from 4mm plate with a 10mm nut welded to the back and a small hole below this. Drill an 11mm hole in your chosen postion on the B post and a 4mm hole below this, attach some stiff wire through the small hole in your monting plate and thread it up the B pillar from below ( I dropped mine in from above as I was replacing the roof)
    Carefully pick up the plate with a short 10mm bolt, nip this up to hold the plate in place and then plug weld your 4mm hole, this will hold the plate in place when you remove the mounting bolt.
    I then cut 4mm plate to bridge diagonally between the B post and the rear wall, drill and slot this to take the reel mounting and weld to the floor, B post and rear cab wall. The other 2 mountings are simple but remember to use plates under the floor, I fixed these by plug welding as above.
    Rods 'n' Sods Junkie rickbwigan's Avatar
    Oct 2012
    wigan
    361
    21
    rickbwigan is offline
    Err, really ?
    your flow chart says none?
    "first used after 1965.....no, as its 1958......none"
    which means it doesnt need seatbelts, but doesnt explain what would be a legal retro fit belt.
    1. Replies: 2
      Last Post: 11-01-2015, 10:06
    2. Shot blasing pot, gm lap belts, STUDEBAKER TRUCK, TIKI
      By tikipaul in forum Stuff - FOR SALE
      Last Post: 26-10-2013, 21:18
    3. Lap Belts
      By wee paul in forum On Topic
      Last Post: 17-07-2009, 18:33
    4. My Chevy Truck and Caddy
      By HOLLYW$$D in forum The Showroom
      Last Post: 09-07-2009, 16:52
    5. Replies: 0
      Last Post: 04-05-2009, 12:48
