60 second tech
Results 1 to 10 of 11
Thread: 60 second tech
    is currently reloading. Taff's Avatar
    where you least expect it
    844
    743
    Taff is offline
    60 second tech
    got any good, simple idea's to make life a bit easier?
    I'll go first. I always mix my plastic filler on a left over bathroom tile. It's a good size, not too heavy, not porous and is easily cleaned after i've finished. I use vinegar to get all the un-used bondo off it.
    anyone else got a little tit-bit that will make life easier for the rest of us?
    A bullet might have your name on it, hand grenades are addressed "to whom it may concern......."
    You can never have too much red wine, too many books or too much ammunition.
    Official Drag Addict.... BRIT DIGGER's Avatar
    manchester
    7,446
    1673
    BRIT DIGGER is offline
    WD40 is great for getting misdirected spray glue off upholstery....
    duraglit polishes bakelite..............
    DRAG RACING IS A DISEASE FOR WHICH THERE IS NO KNOWN CURE.
    Oddlot Drag Racing Team....
    ............."havin fun is usual"
    Old enough to know better KerbycrewGary's Avatar
    Jan 2010
    Naaaarfolk
    3,479
    839
    KerbycrewGary is offline
    Best way to mike life easier.......dont **** off the missus......
    But from a DIY point of view....
    Do not ever use pre mix tile and grout, it does neither, it doesn't stick tiles, and when you grout it dries full of pinholes.......
    I've got loads of these..........just need reminding......
    Racing is Life---anything else is just waiting. Steve McQueen
    Stroker Kustom Jim's Avatar
    Bath
    5,267
    2772
    Kustom Jim is offline
    Lightbulb
    Take VIN from any car you've plundered for parts.
    Godsend for ordering consumable/'rebuild' parts later.
    Rods n Sods is Funkie pixie's Avatar
    Nov 2009
    leicester
    419
    126
    pixie is offline
    Brake cleaner is good for removing grime from fabric.
    Roof linings, Seats etc
    Where,s me marsh mallows
    Official RnS Addict KoppaK's Avatar
    Below the Scrubline
    632
    109
    KoppaK is offline
    Wet flatting is good for removing your finger prints usefull for any gloveless would be burglars
    Member shoebox's Avatar
    x
    1,143
    13
    shoebox is offline
    Rubber hockey pucks (3" diameter x 1" deep) at £1.50 are great to use as trolley jack pads.
    Official RnS Addict Sherwood's Avatar
    Feb 2010
    Stourbridge
    3,130
    2729
    Sherwood is offline
    To prevent corrosion on your battery posts, apply vaseline to them
    Always have a hot pie in your hands in heavy traffic. Each time the traffic grinds to a halt, just reach for the pie. The instant you place it to your lips the traffic begins to move. This works especially well with the molten lava apple turnovers from KFC.
    Viz
    Official RnS Addict paul's Avatar
    in the middle of no place
    777
    19
    paul is offline
    the long bolt trick!!!
    a good tip if you have to replace the flex plate, clutch or sumat where you need to get to the inside the bell housing/rear of the engine etc....this trick means you don't have to drop the trans and it's a piece of **** to line everything up as your not struggling to lift the fecking thing!
    required tools...trolley jack, axle stand and 2 x threaded bar approx 12 inches long, the same size and thread as the trans to bell housing bolts..
    undo the bolts around the top of the bell housing and take them out...
    screw in the threaded bar at the 11.00 and 1.00 positions...
    undo the prop and drop,
    undo the rest of the bell housing bolts
    drop the trans crossmember supporting the end of the trans with the trolley jack.
    you can now slowly move the trans back as the front of the trans will be supported by the 2 long bolts and will go back far enough to access the flex plate etc (I cut a slot in the floor so the shifter can go back too without removing it as well!)
    put an axle stand under the back of the trans for safely
    When your done just slide the trans back up to to the motor and bolt up
    Jan 2010
    kilmarnock
    250
    93fxdl is offline
    if you need to clean up a grotty thread but dont have a tap just use a bolt with a slot cut down it with a hacksaw
    to clean the tread on a bolt, cut a slot on a nut screw onto the bolt, grip the nut in a vice and unscrew the bolt
    jif/cif is good for cleaning vinyl trim (70s headlining)
    cement dust is good for lifting spilt oil
    roadside fix for ignition timing (points) open points and grip a rizzla paper in them then slowly turn the engine over while gently pulling on the paper, when it slips that is the timing point and adjust as required
    take out one of your sidelight holders and extend the wires then whenever you need a work light just sidelights on and pull out the sidelight and away you go
    diesel is a cheap substitute for penetrating oil
    ttfn glenn
    1. Brake tech
      Last Post: 12-05-2010, 10:32
