Chevy 3100 1955 series 1 deluxe pickup 327 sbc 3 speed manuel
View Entry Info: Chevy 3100 1955 series 1 deluxe pickup 327 sbc 3 speed manuel
Category:
Classifieds 1 Item (All details are required to post items in this section.)
Price
£10.000 open to offers p/x etc
Eckington Chesterfield
Condition of Item
used in bits
Description
unfinished project
Results 1 to 7 of 7
    Dec 2013
    over the hill
    125
    21
    low and slow is offline
    Chevrolet 3100 1955 series 1 5 window deluxe
    UK registered been in country 5 years or so
    This is a non running unfinished project
    This is a project lots of parts with this but may require some more to finish
    This is how i bought it and got it home
    some welding has been done drivers cab corner is showing rust but new panel is provided all panels present
    wings/wheel arches been stripped to bear metal also the grill
    front and rear bumpers also bear metal
    Sids front drop axle fitted 3" drop + new slipper springs fitted lowering pick up all round all round
    more picks available can send what you want to your email or pm me and i will send you my mobile if you want to chat
    Parts list
    Sid’s drop axles 3” drop rebuilt front axle new king pins
    Drag link with track rod end conversion
    modified steering arms tre and height corrected
    New steering link with tre conversion
    Modified steering box arm for tre’s
    New front lowered leaf springs with fittings
    New rear lowered leaf springs with fittings
    New ubolts front and rear
    Front caster shims
    Cab corners left side fitted right not
    Filter King FPR007 Metal fuel pressure regulator /filter unit
    Electronic ignition distributor and high power coil
    Alloy distributer clamp and stud kit
    Plug leads x8
    2x securon seatbelts retracting style
    Pro comp 20 circuit wiring harness kit pc 198
    2x round LED indicator/stop/side light units clear but light up in correct colour
    2 chrome vent window catches (new)
    Brake master cylinder floor cover
    Led converted interior light
    Column mounted 3 way switch (indicators)
    Retro looking battery cut off switch
    Door rubber fixing glue
    Adjustable chrome bulkhead mount throttle pedal
    Alloy Coolant Expansion tank
    3x flexy brake hoses
    New wheel cylinders x4
    New master cylinder
    New front brake shoes
    New rear brake shoes
    New handbrake cable
    5 chevy 6 stud truck wheels with hubcaps
    Set of tyres
    set of wheel nuts
    Fel-pro 260-1000 small block chevy gasket set
    New sump and bolts
    Super seal screen rubber
    Used screen (fitted one is cracked)
    Used corner glass x2
    used wind down door glass
    Super seal deluxe window seal kit
    Full door glass seal kit x2
    Full door seal kits x2
    12v heater motor and 2x heater boxes
    12v wiper conversion
    New h4 headlights x2
    53 pickup glass rear lights
    Tow bar frame work and ball UK
    probably much more will update
    I'm open to talking on offers, p/x or swaps into motorbikes 650, mountain bikes ,mechanics tools small van etc
    Mar 2013
    31
    John G is offline
    Hi
    Is she still in a driveable condition or partly dismantled? If you could would you send me the photos plus any more you have in the present state tx. I have a Black jessiejames goose necked pan head harley frame with an millenium 1340 evo fitted etc, jessie hand made tank fender oil tank, sns carb, baker kicker 5 speed and lekky starter, 15 inch swedish rear wheel, re valved built wide shovel forks, billet calipers etc,all finished, mot, reg as a Harley with correctly stamped frame on a w plate for exchange if interested?
    Regards
    John
    Dec 2013
    over the hill
    125
    21
    She's part stripped all running gear ,suspension ,steering ,cab and bonnet still fitted rolling chassis
    Old motorbikes aren't really my thing I'm after something newer trail style
    Mar 2013
    31
    John G is offline
    Ok bud, but its not an old bike but a newish build, a road running custom show bike, but good luck with the sell.
    Dec 2013
    over the hill
    125
    21
    I've got more than 10k in it but I had to put a number down to list it .I need to sell and I'd rather it went to someone here if your genuinely interested pm me and I can pass on my number to chat
    Mar 2013
    31
    John G is offline
    Ok how do I pm you for your phone number...yes I know, not sure what pm stands for, apart from what Im doing now is that, Im an oldy so emojis also confuse me!
    Dec 2013
    over the hill
    125
    21
    P.m.d you John g with my number
    • You may not post new threads
    • You may not post replies
