1 - 6 of 6 Posts
hi
i have a chevy C10 truck 1965
not charging the battery had the battery checked and the alternator is ok
so that leaves the volt regulator any one know how to check it or where can i get another one
thanks richard
Semi Proffessional Prat
Two things spring to mind.
Do you have ignition light, and correct size bulb in it?
Why have you got a regulator, alternators usually have them built in, in my experience?
OK, I've learned something.
I'm Not Jed Clampett
Should be a "Delcotron" setup on your truck. The regulator is a mechanical job with relays inside. There are two different types of regulator used according to whether an ignition warning lamp was factory fitted or not. There's some basic testing info here. | Repair Guides | Firing Orders | Alternator | AutoZone.com
If you're not bothered about originality, it might be worth changing to a Delco 10SI alternator -confusingly also called a "Delcotron" but the SI suffix denotes that it has the internal solid state regulator. You just wire these to your battery connection and ignition warning lamp if you have one.
1 - 6 of 6 Posts
